1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsQt plugin build errors
To: Zhang Yuliang <[email protected]>
Cc: [email protected]
Date: Thu, 03 Nov 2011 22:16:53 +0100
> ./debug\CaObject.o:D:\Qt\Qt
> EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:88:
> undefined reference to `epicsEventCreate'
Please make sure that you have something like
LIBS += -L$$(EPICS_BASE)/lib/$$(EPICS_HOST_ARCH) \
    -lca \
    -lCom \
    -L$$(QCAFRAMEWORK)/qwt-5.2.1/lib \
    -lqwt
in ca_framework/plugins/QCaDesignerPlugin.pro and double check that
EPICS_BASE, EPICS_HOST_ARCH and QCAFRAMEWORK are set correctly . After
changing the project file try to rebuild from scratch:
cd ca_framework/plugins/
make distclean
qmake
make
> EPICS_BASE=C:\EPICS\base-3.14.8.2
> EPICS_HOST_ARCH=win32-x86
That's enough on my Linux machine.
> And in PATH I added "C:\EPICS\base-3.14.8.2\bin\win32-x86" .
I'm not a Windows developer so please correct me if I'm wrong: If you
later want to run the executable you also have to add
C:\EPICS\base-3.14.8.2\lib\win32-x86 to the search path because the
Windows runtime linker only looks for DLLs in the search path. But this
should not play a role during linking...
Hope that helps
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
Re: epicsQt plugin build errors Andrew Johnson
epicsQt plugin build errors Zhang Yuliang
Prev: RE: reading large data arrays over slow networks Jeff Hill
Next: Re: reading large data arrays over slow networks Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: epicsQt plugin build errors Zhang Yuliang
Next: Re: epicsQt plugin build errors Andrew Johnson
