1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsQt plugin build errors
To: [email protected]
Date: Thu, 3 Nov 2011 16:40:55 -0500
On 2011-11-03 Martin Konrad wrote:
> Please make sure that you have something like
> LIBS += -L$$(EPICS_BASE)/lib/$$(EPICS_HOST_ARCH) \
>     -lca \
>     -lCom \
>     -L$$(QCAFRAMEWORK)/qwt-5.2.1/lib \
>     -lqwt
It's possible that your link order might be a problem, make sure that you link
against the ca and Com libraries *after* linking any libraries that calls
them.  In the above case I would suggest moving the -lca and -lCom options
after the -lqwt.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: epicsQt plugin build errors Benjamin Franksen
epicsQt plugin build errors Zhang Yuliang
Re: epicsQt plugin build errors Martin Konrad
Prev: Re: reading large data arrays over slow networks Kevin Peterson
Next: Re: Asyn or StreamDevice Error Messages: vxi11 clientIoCall errno Permission denied clnt_stat 5 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsQt plugin build errors Martin Konrad
Next: Re: epicsQt plugin build errors Benjamin Franksen
