1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsQt plugin build errors
To: <[email protected]>
Date: Thu, 3 Nov 2011 23:35:50 +0100
Am Donnerstag, 3. November 2011, um 22:40:55 schrieb Andrew Johnson:
> On 2011-11-03 Martin Konrad wrote:
> > Please make sure that you have something like
> > LIBS += -L$$(EPICS_BASE)/lib/$$(EPICS_HOST_ARCH) \
> >     -lca \
> >     -lCom \
> >     -L$$(QCAFRAMEWORK)/qwt-5.2.1/lib \
> >     -lqwt
> It's possible that your link order might be a problem, make sure that you
> link against the ca and Com libraries *after* linking any libraries that
> calls them.  In the above case I would suggest moving the -lca and -lCom
> options after the -lqwt.
A quick and dirty method to check that w/o much experimentation is to simply
repeat the whole bunch of -l<libname> options i.e. write
   -lca -lCom -lqwt -lca -lCom -lqwt
If that works ythen ou know what causes the problem and you can then try to
minimize again by finding the correct order... but note that in case two or
more of the libraries you need have circular dependencies you might actually
/have/ to repeat some of them on the command line.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: epicsQt plugin build errors Martin Konrad
Re: epicsQt plugin build errors Andrew Johnson
Prev: Re: Asyn or StreamDevice Error Messages: vxi11 clientIoCall errno Permission denied clnt_stat 5 Benjamin Franksen
Next: Re: reading large data arrays over slow networks Peter Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsQt plugin build errors Andrew Johnson
Next: Re: epicsQt plugin build errors 张玉亮
