1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: About the problem of areaDetector module's compiling and run
To: "?" <[email protected]>, <[email protected]>
Date: Wed, 9 Nov 2011 06:50:36 -0600
Hi Peng,
 > prosilica:writeFloat64: error, status=18 function=51, name=ACQ_PERIOD, value=0.040000
That message can appear on startup because at iocInit it is setting an AcquirePeriod that is inconsistent with the AcquireTime.  It depends on the order in save/restore.  I should fix it, but it is just a warning, and is not serious at all, so don't worry about it.
> Matlab automatically shut off. Did anyone know why?
Did you set EPICS_CA_MAX_ARRAY_BYTES to a large enough value on both the client and server computers?  I have never used Matlab, but I seem to recall hearing that the Channel Access interface only supports reading arrays as doubles (64-bit floating points).  If so, you need to multiply EPICS_CA_MAX_ARRAY_BYTES by 8 over what you would normally use, since the Prosilica is normally sending 8-bit data.  If that is true it makes Matlab quite inefficient for video data.  IDL and ImageJ may be better for imaging clients, since they support reading 8-bit arrays.
Sent: Wed 11/9/2011 5:31 AM
To: [email protected]
Subject: About the problem of areaDetector module's compiling and run
Dear
    I met some problems. When I ran the areaDetector module, it appeared such mistakes.
 13PS1:cam1:AcquirePeriod devAsynFloat64 process error
When I ran it again, this mistake was gone.Did someone come across the problem? How to solve it? Meanwhile there was other question. I used Matlab to read the PV(13PS1:image1:ArrayData). When I used the command that was "A = lcaGet('13PS1:image1:ArrayData');" , Matlab automatically shut off. Did anyone know why?
  Thanks!
Best wishes
        Peng
About the problem of areaDetector module's compiling and run 的
Prev: About the problem of areaDetector module's compiling and run 的
Next: PV in PCAS can not be archived by Channel Archiver Zhang Yuliang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: About the problem of areaDetector module's compiling and run Allison, Stephanie
