1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: About the problem of areaDetector module's compiling and run
To: 的 <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 9 Nov 2011 08:47:20 -0800
Hi Peng,
> I used Matlab to read the
> PV(13PS1:image1:ArrayData). When I used the command that was "A =
> lcaGet('13PS1:image1:ArrayData');" , Matlab automatically shut off. Did anyone know
> why?
Mark Rivers mentioned that EPICS_CA_MAX_ARRAY_BYTES needs to be set properly.
In addition, if 13PS1:image1:ArrayData has an invalid severity, matlab will crash unless you have a try/catch block around the lcaGet:
http://www.slac.stanford.edu/grp/ssrl/spear/epics/extensions/labca/manual/node4.html
or you have called lcaSetSeverityWarnLevel to 14:
http://www.slac.stanford.edu/grp/ssrl/spear/epics/extensions/labca/manual/node24.html
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of ?
> Sent: Wednesday, November 09, 2011 3:31 AM
> To: [email protected]
> Subject: About the problem of areaDetector module's compiling and run
> Dear
>     I met some problems. When I ran the areaDetector module, it appeared such mistakes.
>  prosilica:writeFloat64: error, status=18 function=51, name=ACQ_PERIOD,
> value=0.040000
>  13PS1:cam1:AcquirePeriod devAsynFloat64 process error
> When I ran it again, this mistake was gone.Did someone come across the problem? How to
> solve it? Meanwhile there was other question. I used Matlab to read the
> why?
>   Thanks!
> Best wishes
>        Peng
About the problem of areaDetector module's compiling and run 的
Prev: RE: PV in PCAS can not be archived by Channel Archiver Jeff Hill
Next: Re: [Fwd: RE: IOC make error] Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: About the problem of areaDetector module's compiling and run Mark Rivers
Next: PV in PCAS can not be archived by Channel Archiver Zhang Yuliang
