1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PV in PCAS can not be archived by Channel Archiver
To: "'Zhang Yuliang'" <[email protected]>, "'tech-talk'" <[email protected]>
Date: Wed, 9 Nov 2011 09:32:58 -0700
I agree with Kay that a good way to fault isolate would be to use camonitor to investigate if the PCAS PV is or isn’t sending updates at the same time that the archiver doesn’t appear to be saving updates as expected. Your PCAS service must of course post updates if they will be seen by the archiver. It is also true that your PCAS service may need to provide specifically the PV attributes that are requested by the archiver, and that this could be a difference between a PCAS PV and an IOC’s PV.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
Sent: Wednesday, November 09, 2011 6:14 AM
To: johill; tech-talk
Subject: PV in PCAS can not be archived by Channel Archiver
Hi Jeff
I am encountering a confused problem about archiving PV provided by a PCAS.  The value of pv can archive once and only once, and after that although the value of pv has changed, there is only one value in the channel archiver. It seems that the other values are discarded, and I check the stutus of the ca connetion, it is ok.
The EPICS base used by the PCAS is 3.14.8.2, I want to know whether the pv of pcas can archived by Channel Archiver. The following are ca-test  [pv] outputs:
[zhangyl@timinglinux1 ~]$ ca_test IPV1_REC
native type:    DBR_FLOAT
native count:   1
DBR_STRING      99
DBR_SHORT       99
DBR_FLOAT       99.0000
DBR_ENUM        99
DBR_CHAR        99
DBR_LONG        99
DBR_DOUBLE      99.0000
DBR_STS_STRING   3  2   Value: 99
DBR_STS_SHORT    3  2   Value: 99
DBR_STS_FLOAT    3  2   Value: 99.0000
DBR_STS_ENUM     3  2   Value: 99
DBR_STS_CHAR     3  2   Value: 99
DBR_STS_LONG     3  2   Value: 99
DBR_STS_DOUBLE   3  2   Value: 99.0000
DBR_TIME_STRING  3  2   TimeStamp: 2011/11/09 17:15:20.990038   Value: 99
DBR_TIME_SHORT   3  2   TimeStamp: 2011/11/09 17:15:20.990038   Value: 99
DBR_TIME_FLOAT   3  2   TimeStamp: 2011/11/09 17:15:20.990038   Value: 99.0000
DBR_TIME_ENUM    3  2   TimeStamp: 2011/11/09 17:15:20.990038   Value: 99
DBR_TIME_CHAR    3  2   TimeStamp: 2011/11/09 17:15:20.990038   Value: 99
DBR_TIME_LONG    3  2   TimeStamp: 2011/11/09 17:15:20.990038   Value: 99
DBR_TIME_DOUBLE  3  2   TimeStamp: 2011/11/09 17:15:20.990038   Value: 99.0000
DBR_GR_STRING    3  2   Value: 99
DBR_GR_SHORT     3  2
               0        0       90       85       15       10   Value: 99
DBR_GR_FLOAT     3  2    0
           0.000    0.000   90.000   85.000   15.000   10.000   Value: 99.0000
DBR_GR_ENUM     Channel read request failed
DBR_GR_CHAR      3  2
DBR_GR_LONG      3  2
DBR_GR_DOUBLE    3  2    0
DBR_CTRL_STRING  3  2   Value: 99
DBR_CTRL_SHORT   3  2
               0        0       90       85       15       10        0        0 Value: 99
DBR_CTRL_FLOAT   3  2    0
           0.000    0.000   90.000   85.000   15.000   10.000    0.000    0.000 Value: 99.0000
DBR_CTRL_ENUM   Channel read request failed
DBR_CTRL_CHAR    3  2
DBR_CTRL_LONG    3  2
DBR_CTRL_DOUBLE  3  2    0
           0.000    0.000   90.000   85.000   15.000   10.000    0.000    0.000 Value: 99.000000
DBR_STSACK_STRING       Channel read request failed
DBR_CLASS_NAME  Channel read request failed
I noticed that there are Channel read request failed.
Thank you!
Zhang Yuliang
PV in PCAS can not be archived by Channel Archiver Zhang Yuliang
Prev: RE: IOC make error Mark Rivers
Next: RE: About the problem of areaDetector module's compiling and run Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV in PCAS can not be archived by Channel Archiver Kasemir, Kay
Next: Re: [Fwd: RE: IOC make error] Andrew Johnson
