Hi Florencio,
On 2011-11-09 Cid, Florencio A wrote:
> Thanks for the help, everyone!! I can live with manually edit
> configure/RELEASE as a temporary work-around. When will the revised fix
> to makeBaseApp.pl (mentioned below) be available?
I committed the fix to the 3.14 branch yesterday, and have just created a
patch which is now available through the Known Problems page at
http://www.aps.anl.gov/epics/base/R3-14/12-docs/KnownProblems.html
The fix will also be included in the 3.14.12.2 release that we're currently
working on which is due out before Christmas.
> Also, should this thread (which didn't make it to tech-talk) be added? Not
> sure I'm the one to make the decision.
Done with this reply.
> Thanks again, everyone!!
> Flo
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Tuesday, November 08, 2011 4:35 PM
> To: Janet Anderson
> Cc: Mark Rivers; [email protected]; Cid, Florencio A
> Subject: Re: [Fwd: RE: IOC make error]
> Hi Janet,
> On 2011-11-08 you wrote:
> > Is the following still true? From makeBaseApp.pl:
> > -b base Set the location of EPICS base (full path)
> > If not specified, base path is taken from configure/RELEASE
> > If configure does not exist, from environment
> > If not found in environment, from makeBaseApp.pl location
> That's what the code does:
> # Locate epics_base
> my ($command) = UnixPath($0);
> if ($opt_b) {
> # first choice is -b base
> $epics_base = UnixPath($opt_b);
> } elsif ($release{"EPICS_BASE"}) {
> # second choice is configure/RELEASE
> $epics_base = UnixPath($release{"EPICS_BASE"});
> $epics_base =~s|^\$\(TOP\)/||;
> } elsif ($ENV{EPICS_MBA_BASE}) {
> # third choice is env var EPICS_MBA_BASE
> $epics_base = UnixPath($ENV{EPICS_MBA_BASE});
> } elsif ($command =~ m|/bin/|) {
> # assume script was run with full path to base
> $epics_base = $command;
> $epics_base =~ s|^(.*)/bin/.*makeBaseApp.*|$1|;
> $epics_base and -d "$epics_base" or Cleanup(1, "Can't find EPICS
> base"); $app_epics_base = LocalPath($epics_base);
> $app_epics_base =~ s|^\.\.|\$(TOP)/..|;
> The $app_epics_base value is then used when instantiating the template file
> for configure/RELEASE.
> Mark Rivers wrote:
> > The question is why did makeBaseApp use C:/EPICS/base? I thought it
> > might have to do with how you ran makeBaseApp.pl. I thought running it
> > by typing C:/EPICS/bin/cygwin-x86/makeBaseApp.pl would produce
> > EPICS_BASE as you saw, but running by typing
> > /cygdrive/c/EPICS/base/makeBaseApp.pl would get what you want. But I
> > just tested this, and it does not seem to be the case, even running
> > it as /cygdrive/c/... I still get configure/RELEASE having
> > EPICS_BASE=c:/EPICS/base-3.14.11.
> The LocalPath() call shown on the penultimate line above is converting the
> path string into a Windows-style path when it shouldn't be. Hmm, we
> removed that conversion from the tools/EPICS/Path.pm file back in May, but
> apparently not from its duplicate in makeBaseApp.pl — this is definitely a
> bug which I will fix (properly).
> Thanks all for tracking this down.
> - Andrew
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
RE: About the problem of areaDetector module's compiling and run Allison, Stephanie
Allen Bradley VME-AB1771, 6008-SV2R Szalata, Zenon M.
<2011>
2025
2026
RE: PV in PCAS can not be archived by Channel Archiver Jeff Hill
<2011>
2025
2026
