1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 'Patch' tool for windows
To: "Josh Stein" <[email protected]>, <[email protected]>
Date: Fri, 11 Nov 2011 09:34:16 -0600
Hi Josh,
I know you said “unbundled”, but how about the Cygwin version?
I just downloaded base-3.14.12.1 and then applied the cygwin-path.patch using the latest Cygwin version of patch and it worked fine.
rivers@Rivers-Mobile /cygdrive/c/EPICS/base-3.14.12.1
# patch -p0 < cygwin-path.patch
patching file src/tools/EPICS/Path.pm
From: [email protected] [mailto:[email protected]] On Behalf Of Josh Stein
Sent: Friday, November 11, 2011 8:50 AM
To: [email protected]
Subject: 'Patch' tool for windows
Has anyone found an unbundled Patch tool which works properly for Windows?
I've tried the gwin32 version of patch (which shows as "patch 2.5.9" when 'patch -v' is executed), invoking it as:
patch -p0 < file.patch
this fails with this rather cryptic message:
"Hunk #1 FAILED at 266"
and then dies
Searching on the internet lead me down the path of unix vs. windows line termination woes, but attempts at conversion did not yield a patch file that worked.
Any ideas? It would be wonderful to be able to apply the patches as shown in the "known problems" section of base.
--J
'Patch' tool for windows Josh Stein
Prev: 'Patch' tool for windows Josh Stein
Next: RE: Allen Bradley VME-AB1771, 6008-SV2R Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: 'Patch' tool for windows Andrew Johnson
