1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus - Beckhoff
Date: Fri, 11 Nov 2011 10:57:33 -0800
Hi Mark,
I am running a test soft IOC which reads from a handful of Beckhoff modules.  Just recently it started to crash with segmentation fault.  Here is some of the gdb output looking at the core dump file:
Loaded symbols for /lib/libnss_files.so.2
Core was generated by `../../bin/linux-x86/bkh ./st.cmd'.
Program terminated with signal 11, Segmentation fault.
#0  0x00d5e9bd in writeRead (pasynUser=0x9095664, write_buffer=0x9094dd0 "",
    write_buffer_len=6, read_buffer=0x9095028 "\003 ", read_buffer_len=8,
    timeout=2, nbytesOut=0xb7e091c8, nbytesIn=0xb7e091c4, eomReason=0xb7e091c0)
    at ../../asyn/interfaces/asynOctetSyncIO.c:265
265         status = pioPvt->pasynOctet->flush(pioPvt->octetPvt,pasynUser);
(gdb) bt
#1  0x008a4834 in doModbusIO (pPlc=0x9094ca0, slave=0, function=3, start=4106,
    data="" len=3) at ../drvModbusAsyn.c:1439
#2  0x008a33eb in readPoller (pPlc=0x9094ca0) at ../drvModbusAsyn.c:1087
#3  0x00178244 in start_routine (arg=0x9095fb0)
    at ../../../src/libCom/osi/os/posix/osdThread.c:282
#4  0x00c59832 in start_thread () from /lib/libpthread.so.0
#5  0x0075546e in clone () from /lib/libc.so.6
(gdb)
Before the crash this was printed in the console:
epics> 2011/11/09 05:34:58.852 drvModbusAsyn::doModbusIO port BKH3_3408 error calling writeRead, error=192.168.0.193:502 timeout: Resource temporarily unavailable, nwrite=6/6, nread=0
Segmentation fault (core dumped)
I think that this started when I connected a prosilica camera to the same network hub, a private subnet (192.168.0.x).
The camera is running continuously sending image data at 10 frames/s.
At this point I am not sure, how long it runs before crash.
I will let you know if I discover anything new.
Zen
RE: Modbus - Beckhoff Mark Rivers
Prev: RE: Allen Bradley VME-AB1771, 6008-SV2R Szalata, Zenon M.
Next: RE: Modbus - Beckhoff Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 'Patch' tool for windows Josh Stein
