1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 'Patch' tool for windows
Cc: [email protected]
Date: Fri, 18 Nov 2011 09:02:06 -0600
FYI - I finally got around to doing this and found (for my installation of mingw-get, version 0.4-alpha-1) I had to execute the command as follows:
"mingw-get install msys-patch"
Thanks Andrew
On 11/11/11 11:06 AM, Andrew Johnson wrote:
Hi Josh,
On 2011-11-11 Josh Stein wrote:
Has anyone found an unbundled Patch tool which works properly for Windows?
Since I happen to know that you have a recent version of MinGW installed, I
think you should just be able to use the command "mingw-get install patch" to
install the MSYS version of patch, which I believe will be put into
C:/MinGW/msys/1.0/bin (the number might be different).  It may also add one or
two more things but that's all I had to do yesterday to be able to apply a
Unix patch file on my XP system.
- Andrew
'Patch' tool for windows Josh Stein
Re: 'Patch' tool for windows Andrew Johnson
Prev: RE: recommendations for win64 build graham.cox
Next: Re: documentation for stringout fields Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 'Patch' tool for windows Andrew Johnson
Next: Modbus - Beckhoff Szalata, Zenon M.
