1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: TEMPE_VEAT Exception
Date: Mon, 21 Nov 2011 16:54:39 -0800
I have a very simple VME setup: mvme6100 and SIS3300.
The IOC is built with EPICS R3.14.11 and vxWorks 6.6.  For the SIS3300 I am using gtr R2.3.
I load the IOC, supply a gate to the SIS board and some signals and all works quite well.
Next I insert into the VME crate a VSAM module from BiRa (it’s an A24/D32 no interrupts device, which is basically a 32 channel DVM).  At this point no device driver is built into the IOC software for the VSAM device.
Now, I load the IOC software, without errors.  However, when I enable interrupts in the SIS module, for each trigger (gate) I get the following error:
interrupt:
Clearing VMEbus exception, attrib reg TEMPE_VEAT = 0xc00ccd00
The waveforms from the SIS module look almost as expected, but not quite right.
Next I build into the IOC the device driver for the VSAM module, reload the IOC and still get the same exception when the SIS module is started.
I don’t understand the reason for this. How is it that a simple module (VSAM) in the VME crate can affect the performance of another module (SIS) in the same crate.  I don’t see this behavior with other VME modules in the same crate.
Thanks in advance for any insight into this,
Zen
RE: TEMPE_VEAT Exception Mark Rivers
Re: TEMPE_VEAT Exception Andrew Johnson
Prev: RE: streamdevice problem with 1 byte reply Zhang, Dehong
Next: RE: TEMPE_VEAT Exception Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
