1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: streamdevice problem with 1 byte reply
To: Dirk Zimoch <[email protected]>
Date: Tue, 22 Nov 2011 17:43:49 -0800
Hi Dirk and Mark,
Thank you very much, you solved my problem -- the maxInput=1 did it.
I did not know parameters like these could also be set locally.
In my case (an OPAL 1000 camera), the replies to reads have varing lengthes,
but the replies to the sets are all like ACK or NAK, only one byte.
Thanks for all your generous Givings of great helps!
Dehong
Sent: Tuesday, November 22, 2011 12:24 AM
To: Zhang, Dehong
Cc: [email protected]
Subject: Re: streamdevice problem with 1 byte reply
Zhang, Dehong wrote:
> Hi,
> For some commands, my device replies with only an "ACK" or "NAK",
> no EOS.  Streamdevice gets the byte ok, then gets stuck waiting for
> more input, but there is no more.
> We are "still" using base 3.14.9, asyn 4.10 and streamdevice 2.4.
> The replytimeout is set to 900, readtimeout is 100, maxinput is 0.
> The problem seems to be asyn not timing out.  Could you guys advise
> on what I may have missed?  Is there a quick fix, instead of upgrading
> the whole complex to new versions?
> Thanks much and best regards,
> Dehong
If a protocol has only ACK as a reply, you can work with maxinput=1 and
no interminator. Interminator and maxinput can both be set on a per
protocol base.
If I understand correctly, none of the replies has a terminator, all
start with ACK (if successful) and probably those which return a value
have a fixed number of characters. Is that correct?
inTerminator="";
simpleCommand {
   maxInput=1;
   out "command";
   in ACK;
readValue {
   maxInput=5; # assume 5 char reply: ACK + 4 char int
   out "value?";
   in ACK "%d";
Dirk
streamdevice problem with 1 byte reply Zhang, Dehong
Re: streamdevice problem with 1 byte reply Dirk Zimoch
Prev: Re: EPICS stackoverflow site Andrew Johnson
Next: Re: Undefined symbol of devReadProbe and devRegisterAddress housg
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streamdevice problem with 1 byte reply Dirk Zimoch
Next: TEMPE_VEAT Exception Szalata, Zenon M.
