1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamdevice problem with 1 byte reply
To: "Zhang, Dehong" <[email protected]>
Date: Tue, 22 Nov 2011 09:24:08 +0100
Zhang, Dehong wrote:
For some commands, my device replies with only an "ACK" or "NAK",
no EOS.  Streamdevice gets the byte ok, then gets stuck waiting for
more input, but there is no more.
We are "still" using base 3.14.9, asyn 4.10 and streamdevice 2.4.
The replytimeout is set to 900, readtimeout is 100, maxinput is 0.
The problem seems to be asyn not timing out.  Could you guys advise
on what I may have missed?  Is there a quick fix, instead of upgrading
the whole complex to new versions?
Thanks much and best regards,
Dehong
If a protocol has only ACK as a reply, you can work with maxinput=1 and no interminator. Interminator and maxinput can both be set on a per protocol base.
If I understand correctly, none of the replies has a terminator, all start with ACK (if successful) and probably those which return a value have a fixed number of characters. Is that correct?
inTerminator="";
simpleCommand {
  maxInput=1;
  out "command";
  in ACK;
readValue {
  maxInput=5; # assume 5 char reply: ACK + 4 char int
  out "value?";
  in ACK "%d";
Dirk
RE: streamdevice problem with 1 byte reply Zhang, Dehong
Prev: RE: TEMPE_VEAT Exception Szalata, Zenon M.
Next: Re: StreamDevice: Input "1" does not match format %1r Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: streamdevice problem with 1 byte reply Mark Rivers
Next: RE: streamdevice problem with 1 byte reply Zhang, Dehong
