1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: TEMPE_VEAT Exception
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 21 Nov 2011 19:49:34 -0800
Hi Mark,
Unfortunately, it is not Item 1 or 2 you listed:
1. SIS is A32 and VSAM is A24.
2. VSAM is to the right of SIS.  SIS is indeed generating interrupts, whereas VSAM does not use interrupts.
I don't know about item 3.  I think that it is known that VSAM can coexist in the same crate with interrupt generating modules.  Unfortunately, I have practically no experience with VSAM.  I am beginning to learn its use, which I need to know for upgrading some older VME system software.
Thanks Mark,
Zen
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Monday, November 21, 2011 6:56 PM
> To: Szalata, Zenon M.; [email protected]
> Hi Zen,
> Here are a couple of  possibilities.
> 1) Are you sure that the SIS3300 and the VSAM do not have an address
> conflict?  What address range does each module occupy, and in what VME
> address space(s)?
> 2) I am assuming that the SIS3300 does generate interrupts.  Interrupt
> requests in the VME crate must propogate from the device to the CPU (left-
> most slot).  As the request travels to the CPU, each card must pass the
> interrupt request if it is not requesting itself on that interrupt level or a higher
> one.  Perhaps the VSAM module is not correctly passing the interrupt request.
> Is the VSAM module installed between the SIS3300 and the CPU, or is it
> installed to the right of the SIS3300? If it is installed to the left, try moving it
> to the right and see if that fixes the problem.
> 3) Another possibility is that the VSAM is incorrectly responding to the
> interrupt acknowledge cycle.
> If it is not something simple like 1), then you will probably need a VME bus
> analyzer to figure out what is going wrong.
> Mark
> ________________________________
> From: [email protected] on behalf of Szalata, Zenon M.
> Sent: Mon 11/21/2011 6:54 PM
> To: [email protected]
> Subject: TEMPE_VEAT Exception
> I have a very simple VME setup: mvme6100 and SIS3300.
> The IOC is built with EPICS R3.14.11 and vxWorks 6.6.  For the SIS3300 I am
> using gtr R2.3.
> I load the IOC, supply a gate to the SIS board and some signals and all works
> quite well.
> Next I insert into the VME crate a VSAM module from BiRa (it's an A24/D32 no
> interrupts device, which is basically a 32 channel DVM).  At this point no
> device driver is built into the IOC software for the VSAM device.
> Now, I load the IOC software, without errors.  However, when I enable
> interrupts in the SIS module, for each trigger (gate) I get the following error:
> interrupt:
> Clearing VMEbus exception, attrib reg TEMPE_VEAT = 0xc00ccd00
> The waveforms from the SIS module look almost as expected, but not quite
> right.
> Next I build into the IOC the device driver for the VSAM module, reload the IOC
> and still get the same exception when the SIS module is started.
> I don't understand the reason for this. How is it that a simple module (VSAM)
> in the VME crate can affect the performance of another module (SIS) in the
> same crate.  I don't see this behavior with other VME modules in the same
> crate.
> Thanks in advance for any insight into this,
> Zen
TEMPE_VEAT Exception Szalata, Zenon M.
RE: TEMPE_VEAT Exception Mark Rivers
Prev: RE: streamdevice problem with 1 byte reply Mark Rivers
Next: Re: streamdevice problem with 1 byte reply Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: TEMPE_VEAT Exception Mark Rivers
Next: Re: TEMPE_VEAT Exception Andrew Johnson
