1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: TEMPE_VEAT Exception
Date: Tue, 22 Nov 2011 12:08:21 -0500
Andrew Johnson wrote:
So basically your code is trying to read a D32 value from an A32 location with a supervisory AM, but it's not getting any response (or the target is rejecting an access of that AM or size).
Zenon--
It's been a number of years since I used a BiRa VSAM, but I recall it had some peculiarities with its VME interface (among other quirks) which I needed to work through at the time. (The VSAM is a very nice card in terms of performance, though.)
With Andrew's analysis of your error message, and Google to help my memory, this sounds like your problem . . .
"If you have an A32/D32 module at 0x80400000 and a VSAM at 0x00400000, the VSAM will generate a bus error for accesses to the other module."
http://www.slac.stanford.edu/grp/cd/soft/epics/site/vsam/vsam_busError.txt
In my case, I did not cut the trace, but instead ensured that I didn't have the address overlap.
Steven Hartman
[email protected]
RE: TEMPE_VEAT Exception Szalata, Zenon M.
Re: TEMPE_VEAT Exception Andrew Johnson
Prev: Re: TEMPE_VEAT Exception Andrew Johnson
Next: Re: undefined symbol when loading EPICS IOC on vxWorks Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: TEMPE_VEAT Exception Szalata, Zenon M.
