1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base 3.14.12.2-rc1 available for testing
To: "Mark Rivers" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 29 Nov 2011 13:12:32 -0600
Hi Mark,
On 2011-11-29 Mark Rivers wrote:
> corvette:osi/os/WIN32>diff -u osdTime.cpp.orig osdTime.cpp
> --- osdTime.cpp.orig    2011-11-29 11:40:13.304344427 -0600
> +++ osdTime.cpp 2011-11-29 11:41:19.705649538 -0600
> @@ -60,6 +60,8 @@
>  // for mingw
>  #if !defined ( MAXLONGLONG )
>  #define MAXLONGLONG LL_CONSTANT(0x7fffffffffffffff)
> +#endif
> +#if !defined ( MINLONGLONG )
>  #define MINLONGLONG LL_CONSTANT(~0x7fffffffffffffff)
>  #endif
I will apply that change, thanks.
> It also generated this warning, which does not look good:
> cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355
> /D_WIN32_WINNT=0x0503   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I.
> ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdMutex.c
> osdMutex.c
> ..\..\..\src\libCom\osi\os\WIN32\osdMutex.c(41) : warning C4005:
> '_WIN32_WINNT' : macro redefinition
>         command-line arguments :  see previous definition of
> '_WIN32_WINNT'
Janet and I are trying to work out where your command-line flag
/D_WIN32_WINNT=0x0503 is coming from because it's not a standard part of Base.
Is it from some site-specific configuration you've used?  We don't see it
ourselves on win32-x86 builds.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
RE: EPICS Base 3.14.12.2-rc1 available for testing Mark Rivers
EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
Prev: measComp R1-0 released Mark Rivers
Next: RE: EPICS Base 3.14.12.2-rc1 available for testing Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS Base 3.14.12.2-rc1 available for testing Mark Rivers
