1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: measComp R1-0 released
To: "EPICS tech-talk" <[email protected]>
Date: Tue, 29 Nov 2011 13:02:52 -0600
Folks,
I have created a new EPICS module called measComp that supports USB
devices from Measurement Computing Corporation.  The two devices that
are supported in this initial release are:
USB-1608GX-2AO
(http://www.mccdaq.com/usb-data-acquisition/USB-1608GX-2AO.aspx)
This module costs ~$800 has the following features:
* 16-bit analog inputs
   o 16 single-ended channels or 8 differential channels
   o Programmable per-channel range: +-1V, +-2V, +-5V, +-10V
   o 500 kHz total maximum input rate, i.e. 1 channel at 500 kHz, 8
channels at 62.5 kHz, etc.
   o Internal or external trigger. External trigger shared with analog
outputs.
   o Internal or external clock, input and output signals.
   o 4 kSample input FIFO, unlimited waveform length
* 16-bit analog outputs
   o 2 channels, fixed +-10V range
   o 500 kHz total maximum input rate, i.e. 1 channel at 500 kHz, 2
channels at 250 kHz
inputs.
   o 2 kSample output FIFO, unlimited waveform length
* Digital inputs/outputs
   o 8 signals, individually programmable as inputs or outputs
* Pulse generator
   o 1 output
   o 64MHz clock, 32-bit registers
   o Programmable period, width, number of pulses, polarity
* Counters
   o 2 inputs
   o 20 MHz maximum rate, 32-bit registers
The EPICS driver supports all of these features, including a 2-channel
500 kHz 16-bit arbitrary waveform generator, and an 8-channel 500 kHz
16-bit waveform digitizer.
USB-4303 (http://www.mccdaq.com/usb-data-acquisition/USB-4303.aspx)
This module cost ~$350 and has the following features:
* Counter/Timers
   o 2 CTS9513 counter timer chips. Each chip features
* 5 16-bit 20MHz programmable up/down counters
* Programmable pulse generation
* Programmable delay generator
* Event counting
   o 8 inputs
   o 8 outputs
The EPICS driver includes support for the EPICS scaler record, making
this a very inexpensive way to get EPICS scaler support.
The home page for this new module is here:
http://cars9.uchicago.edu/software/epics/measComp.html
The documentation is here:
http://cars9.uchicago.edu/software/epics/measCompDoc.html
Cheers,
Prev: RE: EPICS Base 3.14.12.2-rc1 available for testing Mark Rivers
Next: Re: EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Micro Research cPCI EVG support (request) Michael Davidsaver
Next: About matplotlib draw picture 闫芬
