1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base 3.14.12.2-rc1 available for testing
To: EPICS Tech Talk <[email protected]>
Date: Tue, 29 Nov 2011 14:51:39 -0600
On 11/28/11 4:58 PM, Andrew Johnson wrote:
> The first release candidate for the 3.14.12.2 version of Base is now available
> on the website for general testing.  Links to the tarfile and Release Notes
> can be found at http://www.aps.anl.gov/epics/base/R3-14/12.php
> Please report any problems you find to tech-talk.  If no major issues are
> discovered before December 12th we will release 3.14.12.2 on that date.
I was able to build successfully on Mac OS X 10.7.2 with
ARCH_CLASS = x86_64 using GCC and Clang.
Attached are the build logs for GCC and Clang, each of which
produced some warning messages.
Also attached are the "runtests" logs for the GCC and Clang
builds.  Both reported "All tests successful" but some test
cases printed messages that look abnormal.  For example:
  epicsThreadOnceTest.t ...... 1/11 Recursive epicsThreadOnce()
  initialization Thread recurse (0x7fd642e00000) can't proceed,
  suspending.
And:
  macEnvExpandTest.t ......... 1/71 macLib: macro FOO is
  undefined (expanding string ${FOO})
And:
  taskwdTest.t ............... 3/8 Thread testTask2
  (0x7fdc8c000000) suspended
Lewis
Attachment: base-3.14.12.2-rc1-clang.txt.gz
Description: GNU Zip compressed data
Attachment: base-3.14.12.2-rc1-gcc.txt.gz
Attachment: base-3.14.12.2-rc1-tests-clang.txt.gz
Attachment: base-3.14.12.2-rc1-tests-gcc.txt.gz
Re: EPICS Base 3.14.12.2-rc1 available for testing Eric Norum
Re: EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
Re: EPICS Base 3.14.12.2-rc1 available for testing Pelaia II, Tom
Prev: RE: EPICS Base 3.14.12.2-rc1 available for testing Mark Rivers
Next: RE: EPICS Base 3.14.12.2-rc1 available for testing Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS Base 3.14.12.2-rc1 available for testing Eric Norum
