1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base 3.14.12.2-rc1 available for testing
To: [email protected]
Date: Tue, 29 Nov 2011 15:51:13 -0600
Hi Lewis,
On 2011-11-29 J. Lewis Muir wrote:
> Attached are the build logs for GCC and Clang, each of which
> produced some warning messages.
Some of those Clang warnings are new to me and interesting, a few others are
things we can't change in the 3.14 series for reasons of portability or
backwards compatibility.
> Also attached are the "runtests" logs for the GCC and Clang
> builds.  Both reported "All tests successful" but some test
> cases printed messages that look abnormal.  For example:
>   epicsThreadOnceTest.t ...... 1/11 Recursive epicsThreadOnce()
>   initialization Thread recurse (0x7fd642e00000) can't proceed,
>   suspending.
> And:
>   macEnvExpandTest.t ......... 1/71 macLib: macro FOO is
>   undefined (expanding string ${FOO})
> And:
>   taskwdTest.t ............... 3/8 Thread testTask2
>   (0x7fdc8c000000) suspended
As Eric said, those messages are all normal, they come from tests of routines
that send output to stderr when they fail.  The tests are expecting the
failure in all cases, we just haven't written code to suppress or redirect the
stderr output.  The pass/fail result of the test is always definitive.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
Re: EPICS Base 3.14.12.2-rc1 available for testing J. Lewis Muir
Prev: Re: EPICS Base 3.14.12.2-rc1 available for testing Eric Norum
Next: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS Base 3.14.12.2-rc1 available for testing Pelaia II, Tom
