1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
Date: Thu, 1 Dec 2011 15:50:37 -0800
Hi Andrew,
I think that's a great idea. A warning message would be a big help for those not yet familiar with the building system.
Luciano
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Thursday, December 01, 2011 15:44
To: [email protected]
Subject: Re: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
Hi Luciano,
On 2011-12-01 Piccoli, Luciano wrote:
> This problem would have easily been caught if the configure/Makefile had
> the CHECK_RELEASE=YES. It was set to NO in the module I used as a starting
> point.
CHECK_RELEASE also has a WARN setting which I would always recommend using
instead of NO if you need to override an inconsistency (and you understand
what you're doing).  Maybe setting it to NO should print a warning?
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
Re: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Andrew Johnson
Prev: Re: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Andrew Johnson
Next: Re: EPICS Base 3.14.12.2-rc1 available for testing Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
