1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base 3.14.12.2-rc1 available for testing
To: Jeff Hill <[email protected]>
Cc: EPICS <[email protected]>
Date: Fri, 02 Dec 2011 09:34:14 +0100
Hi Jeff
Jeff Hill wrote:
I wonder why no other compiler complains? Even though the C++ standard
states that the system will generate a destructor for you if you don't,
declaring the destructor pure virtual in the base class clearly requests
that the user defines one.
If the function is virtual in the base class then of course it must be
virtual in any derived class - independent of whether the virtual keyword is
present or not. Of course virtual destructors are special and if there is a
virtual destructor in the base then there must also be one in the derived,
but I know of no restriction which prevents the compiler from implicitly
generating a virtual destructor. Nevertheless, if it causes issues we will
attend to it.
The point is that it is *pure* virtual (i.e. unimplemented): ... = 0;
This makes the base class abstract and no instance can be made. Derived classes stay abstract unless all pure virtual functions are defined. Here, the destructor is pure virtual and thus must be defined before the derived class can be used.
That a virtual function stays virtual in derived classes has little to do with this problem. The question is not if the destructor is virtual. The problem is that there is no destructor at all.
"/usr/include/sys/time.h", line 50: Error: Type name expected instead of
"time_t".
I do always try to explicitly import from the standard name space when using
the "#include <ctime>" form, which is the correct approach for maximizing
portability, but obviously neglected to do so in this situation.
Your code is correct, the bug is in the ctime or time.h system header. But importing the std namespace before including ctime fixes the problem.
Dirk
Andrew: are you attending to this? If not, I will take care of it. I can
have a look at the casStreamOS.cc", line 304, issue also.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
-----Original Message-----
On Behalf Of Dirk Zimoch
Sent: Wednesday, November 30, 2011 8:57 AM
To: Andrew Johnson
Cc: EPICS tech-talk
Andrew Johnson wrote:
The first release candidate for the 3.14.12.2 version of Base is now
available
on the website for general testing.  Links to the tarfile and Release
Notes
can be found at http://www.aps.anl.gov/epics/base/R3-14/12.php
Please report any problems you find to tech-talk.  If no major issues
are
discovered before December 12th we will release 3.14.12.2 on that date.
Thanks to everyone who has helped with this process.
- Andrew
I tried it on my old sun solaris. It failed with:
/afs/psi.ch/sys/@sys/sepp/bin/CC -c  -D_POSIX_C_SOURCE=199506L
-D_XOPEN_SOURCE=500            -DUNIX  -DSOLARIS=8 -mt  -D__EXTENSIONS__
   -O   +w             -I. -I../O.Common -I. -I..
-I../../../include/os/solaris -I../../../include        ../casw.cpp
"../udpiiu.h", line 158: Error: Cannot declare a member of the abstract
type udpiiu::M_repeaterTimerNotify.
"../casw.cpp", line 306: Warning: statement is unreachable.
1 Error(s) and 1 Warning(s) detected.
make[3]: *** [casw.o] Error 1
make[3]: Leaving directory
`/afs/psi.ch/group/8431/dirk/solaris/base-3.14.12.2-rc1/src/ca/O.solaris-
sparc'
make[2]: *** [install.solaris-sparc] Error 2
The reason is that the base class repeaterTimerNotify has a pure virtual
destructor  (virtual ~repeaterTimerNotify () = 0;) which is not
overwritten by udpiiu::M_repeaterTimerNotify. Thus
udpiiu::M_repeaterTimerNotify is still abstract and cannot be
instantiated.
Add: ~M_repeaterTimerNotify () {};
After fixing this I get:
-I../../../../include/os/solaris -I../../../../include
../epicsTimeTest.cpp
"time_t".
1 Error(s) detected.
make[3]: *** [epicsTimeTest.o] Error 1
The problem is a bug in the way the solaris compiler handles the
standard C header file time.h when included from C++ via ctime. It hides
the typedef long time_t; into namespace std and later in the same header
file fails to find it.
To fix this, I had to move
using namespace std;
in front of
#include <ctime>
Next problem:
   -O   +w           -xcode=pic32  -I. -I../O.Common -I. -I..
-I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket
-I../../../../src/cas/generic/st -I../../../../src/cas/../ca
../../../../src/cas/generic/st/casStreamOS.cc
"../../../../src/cas/generic/st/casStreamOS.cc", line 304: Error:
"casStreamOS::armRecv()" has already been called and cannot be defined
inline.
make[4]: *** [casStreamOS.o] Error 1
Damn, why is this an error instead of a warning? Anyway:
Put inline void casStreamOS::armRecv() before casStreamIOWakeup::expire().
cap5 does not work at all because my perl version has been compiled with
a different compiler and all the compiler options don't work. The reason
was that I needed a newer perl version to compile EPICS than the one
that was already installed. It seems the guy who compiled perl 5.8.8
used gcc instead of the system compiler.
Maybe the cap5/Makefile should check for compatibility between the
current compiler and the options returned from perlConfig.pl
(perlConfig.pl cc) or change not only CFLAGS but CC too.
Otherwise all is fine :-)
I successfully compiled for
vxWorks 5.5 ppc604 (aka Tornado 2.2)
vxWorks 6.3 ppc603 (used on cRIO)
vxWorks 6.7 ppc604
linux xscale_be (Montavista gcc version 3.4.3)
linux ppc405 (embedded in Virtex 5, Crosstool gcc version 4.0.2)
Scientific Linux 5.1 x86
Scientific Linux 6.0 x86_64
Scientific Linux 6.0 x86 (cross build on 64 bit machine)
For your info:
 > perl -v
This is perl, v5.8.8 built for sun4-solaris
 > perl perlConfig.pl cc
gcc
 > /afs/psi.ch/sys/@sys/sepp/bin/cc -V
cc: Sun WorkShop 6 update 2 C 5.3 2001/05/15
 > uname -a
SunOS pssvxw.psi.ch 5.8 Generic_108528-19 sun4u sparc SUNW,Sun-Blade-100
Dirk
RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
Re: EPICS Base 3.14.12.2-rc1 available for testing Dirk Zimoch
Prev: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
Next: [help] EPICS build no good Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
Next: RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
