1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [help] EPICS build no good
To: Janet Anderson <[email protected]>, [email protected]
Date: Mon, 5 Dec 2011 19:16:31 +0300
it had been set so prior
2011/12/5 Janet Anderson <[email protected]>
Looks like the definitions of CC and CCC  are incorrect.  Try  setting CC=gcc and CCC=g++ in configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw.
Janet
Pavel Masloff wrote:
Hey Mark,
I don't know where this error comes from (the single quotes). I thought running softIoc.exe is a simple way to check the installation.
No, your suggestions didn't work (sorry, partly in Russian, I can translate if you need):
"Installing generic include file ../../../include/tsDefs.h"
windres -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../
src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../Com.rc Com.coff
g++ -c             -D_MINGW     -O3   -Wall     -fpermissive  -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
de/os/WIN32 -I../../../include        ../../../src/libCom/bucketLib/bucketLib.c
../../../src/libCom/bucketLib/bucketLib.c: В функции <ITEM** bucketStringCompare(ITEM**, const void*)>:
../../../src/libCom/bucketLib/bucketLib.c:125:21: предупреждение: некорректное преобразование из <const void*> в <const
char*> [-fpermissive]
../../../src/libCom/bucketLib/bucketLib.c: В функции <BUCKETID bucketUnsignedHash(BUCKET*, const void*)>:
../../../src/libCom/bucketLib/bucketLib.c:147:25: предупреждение: некорректное преобразование из <const void*> в <const
unsigned int*> [-fpermissive]
../../../src/libCom/bucketLib/bucketLib.c: В функции <BUCKETID bucketStringHash(BUCKET*, const void*)>:
../../../src/libCom/bucketLib/bucketLib.c:197:21: предупреждение: некорректное преобразование из <const void*> в <const
de/os/WIN32 -I../../../include        ../../../src/libCom/ring/epicsRingPointer.cpp
de/os/WIN32 -I../../../include        ../../../src/libCom/ring/epicsRingBytes.c
../../../src/libCom/ring/epicsRingBytes.c: В функции <void* epicsRingBytesCreate(int)>:
../../../src/libCom/ring/epicsRingBytes.c:42:78: предупреждение: некорректное преобразование из <void*> в <ringPvt* {aka
 ringPvt*}> [-fpermissive]
../../../src/libCom/ring/epicsRingBytes.c:44:63: предупреждение: некорректное преобразование из <void*> в <volatile char
*> [-fpermissive]
de/os/WIN32 -I../../../include        ../../../src/libCom/calc/postfix.c
../../../src/libCom/calc/postfix.c:129:1: предупреждение: deprecated conversion from string constant to <char*> [-Wwrite -strings]
../../../src/libCom/calc/postfix.c:163:1: предупреждение: deprecated conversion from string constant to <char*> [-Wwrite -strings]
../../../src/libCom/calc/postfix.c: В функции <long int postfix(const char*, char*, short int*)>:
../../../src/libCom/calc/postfix.c:272:42: предупреждение: некорректное преобразование из <int> в <rpn_opcode> [-fpermis
sive]
de/os/WIN32 -I../../../include        ../../../src/libCom/calc/calcPerform.c
de/os/WIN32 -I../../../include        ../../../src/libCom/cvtFast/cvtFast.c
de/os/WIN32 -I../../../include        ../../../src/libCom/cxxTemplates/resourceLib.cpp
../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/cxxTemplates/epicsOnce.cpp
In file included from ../../../src/libCom/cxxTemplates/epicsOnce.cpp:29:0:
../../../src/libCom/cxxTemplates/epicsSingleton.h:37:5: ошибка: <size_t> не является именем типа ../../../src/libCom/cxxTemplates/epicsSingleton.h: In constructor <SingletonUntyped::SingletonUntyped()>:
../../../src/libCom/cxxTemplates/epicsSingleton.h:162:23: ошибка: в классе <SingletonUntyped> не имеет поля с именем <_refCount>
mingw32-make[3]: *** [epicsOnce.o] Error 1
mingw32-make[3]: Leaving directory `C:/epics/base/bin/win32-x86-mingw/src/libCom/O.win32-x86-mingw'
mingw32-make[2]: *** [install.win32-x86-mingw] Error 2
mingw32-make[2]: Leaving directory `C:/epics/base/bin/win32-x86-mingw/src/libCom'
mingw32-make[1]: *** [libCom.install] Error 2
mingw32-make[1]: Leaving directory `C:/epics/base/bin/win32-x86-mingw/src'
mingw32-make: *** [src.install] Error 2
mingw32-make: Leaving directory `C:/epics/base/bin/win32-x86-mingw'
On Sun, Dec 4, 2011 at 11:46 PM, Mark Rivers <[email protected]> wrote:
I don't know about the problem with softIoc.  Where is it getting those single quotes?
Did you try my suggestion of -fpermissive when building with MinGW?  I think it should have at least eliminated the error you reported.
Sent: Sun 12/4/2011 1:48 PM
To: Mark Rivers
Cc: [email protected]; [email protected]
Hey Mark,
The base I am trying to build is 3.14.12.1.
Mingw32-make didn't work. So i tried Microsoft Visual Studio 2010 Express. The compilation ended successfully with a few warnings.
However, when I try to run softIoc.exe, I see the following error:
d:\>softIoc
filename="..\dbLexRoutines.c" line number=243
Invalid argument dbRead opening file 'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
Pavel
On Sat, Dec 3, 2011 at 1:26 AM, Mark Rivers <[email protected]> wrote:
       Hi Pavel,
       What version of base is this?
       I think you can avoid this error by adding this line to base/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
       USR_CFLAGS += -fpermissive
       USR_CXXFLAGS += -fpermissive
       But if this is the latest version of base then I think there is an error that should be fixed.
       Sent: Friday, December 02, 2011 4:13 PM
       To: Mark Rivers
       Mark,
       I did what you'd proposed.
       This is what i get:
       g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/
       /src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../s
       ../../../src/libCom/bucketLib/bucketLib.c: In function <ITEM** bucketStringCompare(ITEM**, const void*)>:
       ../../../src/libCom/bucketLib/bucketLib.c:125:21: error: incorrect transform from <const void*> to <const char*>
       -fpermissive]
       ../../../src/libCom/bucketLib/bucketLib.c: in function <BUCKETID bucketUnsignedHash(BUCKET*, const void*)>:
       ../../../src/libCom/bucketLib/bucketLib.c:147:25: error: incorrect transform from <const void*> to <const unsigne
       ../../../src/libCom/bucketLib/bucketLib.c: In function <BUCKETID bucketStringHash(BUCKET*, const void*)>:
       ../../../src/libCom/bucketLib/bucketLib.c:197:21: error: incorrect transform from <const void*> to <const char*>
       -fpermissive]
       mingw32-make[3]: *** [bucketLib.o] Error 1
       On Sat, Dec 3, 2011 at 12:45 AM, Mark Rivers <[email protected]> wrote:
       Hi Pavel,
       I understand now.  I thought you were just using MinGW for gnumake.  But you want to use the gcc compiler as well.
       You have set the wrong value for EPICS_HOST_ARCH.  You have set it to win32-x86, which is the architecture that requires Visual Studio.
       You need to set the environment variable EPICS_HOST_ARCH to win32-x86-mingw.  That will use gcc.
       Sent: Friday, December 02, 2011 3:41 PM
       To: Mark Rivers; [email protected]
       Hi Mark,
       Do I really need MS Visual Studio?
       According to this (http://www.aps.anl.gov/epics/base/win32.phphttp://www.aps.anl.gov/epics/base/win32.php):
       Download and install a compiler:
       * Microsoft Visual C++ Express 2010, or
       * MinGW version of GCC
       * You can also use Microsoft's commercial C++ development tools if you have them.
       I used MinGW. I see 'or' here.
       On Sat, Dec 3, 2011 at 12:27 AM, Mark Rivers <[email protected]> wrote:
       Hi Pavel,
       I think the problem is that you have not set up your environment for Visual Studio.  Your PATH environment variable does not include the path to the Visual Studio compiler.  You need to execute the "vcvarsall.bat file that comes with Visual Studio.
       This is the batch file I use to set up EPICS builds for win32-x86.
       rem This file sets up for an EPICS win32-x86 build
       set EPICS_HOST_ARCH=win32-x86
       rem This is the location of "make"
       set PATH=C:\Program Files\GnuWin32\bin;C:\Perl\bin;H:\epics\base\bin\win32-x86;%PATH%
       "C:\Program Files\Microsoft Visual Studio 9.0\VC\vcvarsall.bat" x86
       From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
       Sent: Friday, December 02, 2011 2:52 PM
       To: [email protected]; Dirk Zimoch; [email protected]
       Subject: [help] EPICS build no good
       Hello,
       This is my first attempt ever to build EPICS (and it's the first time I try to compile something really big, as a matter of fact).
       In accordance with the following instructions (http://www.aps.anl.gov/epics/base/win32.php) and recommendations by Dirk Zimoch (thanks!), I tried to build EPICS baseR3.14.12.1 on Windows 7 Starter using:
       * ActiveState Perl (ActivePerl-5.14.2.1402-MSWin32-x86)
       This is what I get :
       rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../.
       ./../../include/os/WIN32 -I../../../include        -fo Com.res ../Com.rc
       process_begin: CreateProcess(NULL, rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/l
       /../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/l
       er -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include -fo Com.res ../Com.rc, ...) failed.
       make (e=2): No such file.
       mingw32-make[3]: *** [Com.res] Error 2
       mingw32-make[3]: Leaving directory `C:/epics/base/bin/win32-x86/src/libCom/O.win32-x86'
       mingw32-make[2]: *** [install.win32-x86] Error 2
       mingw32-make[2]: Leaving directory `C:/epics/base/bin/win32-x86/src/libCom'
       mingw32-make[1]: Leaving directory `C:/epics/base/bin/win32-x86/src'
       mingw32-make: Leaving directory `C:/epics/base/bin/win32-x86'
       Why can it be so? The same thing using GnuWin32:
       I set the PATH Environment Variable to:
       C:\Perl\site\bin;C:\Perl\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\QuickTime\QTSystem\;C:\MinGW\bin;C:\GnuWin32\bin
       I don't know if there was a need to do so. Because I can see it's mentioned in the win32.bat file. Here's my win32.bat (in the ming32-make case):
       @ECHO OFF
       REM *************************************************************************
       REM  Copyright (c) 2002 The University of Chicago, as Operator of Argonne
       REM      National Laboratory.
       REM  Copyright (c) 2002 The Regents of the University of California, as
       REM      Operator of Los Alamos National Laboratory.
       REM  EPICS BASE Versions 3.13.7
       REM  and higher are distributed subject to a Software License Agreement found
       REM  in file LICENSE that is included with this distribution.
       REM  Revision-Id: [email protected]
       REM
       REM  Site-specific EPICS environment settings
       REM
       REM  sites should modify these definitions
       REM ======================================================
       REM    ====== REQUIRED ENVIRONMENT VARIABLES FOLLOW ======
       REM   ---------------- WINDOWS ---------------------------
       REM ----- WIN95 -----
       REM set PATH=C:\WINDOWS;C:\WINDOWS\COMMAND
       REM ----- WINNT, WIN2000  -----
       REM set PATH=C:\WINNT;C:\WINNT\SYSTEM32
       REM ----- WINXP, Vista, Windows 7 -----
       set PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\Wbem
       REM   ---------------- make and perl ---------------------
       REM   --------------- ActiveState perl -------------------
       set PATH=C:\Perl\bin;%PATH%
       REM    --------------- mingw make ------------------------
       set PATH=C:\mingw\bin;%PATH%
       REM set PATH=C:\mingw-make82-3\bin;%PATH%
       REM   --------------- gnuwin32 make ----------------------
       REM set PATH=C:\gnuwin32\bin;%PATH%
       REM ---------------- cygwin tools ------------------------
       REM    (make & perl if above perl and make are REMs)
       REM    Dont use cygwin GNU make and Perl!
       REM    cygwin contains tk/tcl, vim, perl, and many unix tools
       REM    need grep from here NOT from cvs directory
       REM set PATH=%PATH%;.;..
       REM set PATH=%PATH%;c:\cygwin\bin
       REM   --------------- Visual c++ -------------------------
       REM    ------ Microsoft Visual Studio 2005 ------
       REM call "C:\Program files\Microsoft Visual Studio 8\VC\vcvarsall.bat" x86_amd64
       REM set PATH=%PATH%;C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin
       REM set INCLUDE=%INCLUDE%;C:\Program Files\Microsoft SDKs\Windows\v6.0A\include
       REM REM set LIBPATH=%LIBPATH%;C:\Program Files\Microsoft SDKs\Windows\v6.0A\lib
       REM set LIB=%LIB%;C:\Program Files\Microsoft SDKs\Windows\v6.0A\lib
       REM    ------ Microsoft Visual Studio 2008 ------
       REM call "C:\Program files\Microsoft Visual Studio 9.0\VC\bin\vcvars32.bat"
       REM call "C:\Program files\Microsoft Visual Studio 9.0\VC\vcvarsall.bat" x86_amd64
       REM set    PATH=C:\Program Files\Microsoft SDKs\Windows\v7.0\bin;%PATH%
       REM set INCLUDE=C:\Program Files\Microsoft SDKs\Windows\v7.0\include;%INCLUDE%
       REM set LIBPATH=C:\Program Files\Microsoft SDKs\Windows\v7.0\lib;%LIBPATH%
       REM set     LIB=C:\Program Files\Microsoft SDKs\Windows\v7.0\lib;%LIB%
       REM    ----- Visual Studion 2010 -----
       REM --  windows-x64 ---
       REM call "C:\Program files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x64
       REM --  win32-x86 ---
       REM call "C:\Program files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x86
       REM --------------- EPICS --------------------------------
       REM set EPICS_HOST_ARCH=windows-x64
       set PATH=%PATH%;C:\epics\base\bin\%EPICS_HOST_ARCH%
       REM set PATH=%PATH%;G:\epics\extensions\bin\%EPICS_HOST_ARCH%
       REM ------- OPTIONAL ENVIRONMENT VARIABLES FOLLOW --------
       REM ----------------- remote CVS -------------------------
       REM set CVS_RSH=c:/cygwin/bin/ssh.exe
       REM set CVSROOT=:ext:[email protected]:/usr/local/epicsmgr/cvsroot
       REM set HOME=c:/users/%USERNAME%
       REM set HOME=c:/users/jba
       REM ------------------- Bazaar ---------------------------
       REM set PATH=%PATH%;C:\Program files\Bazaar
       REM ----------------- GNU make flags ---------------------
       set MAKEFLAGS=-w
       REM -------------- vim (use cygwin vim ) -----------------
       REM HOME needed by vim to write .viminfo file.
       REM VIM needed by vim to find _vimrc file.
       REM set VIM=c:\cygwin
       REM --------------- Epics Channel Access -----------------
       REM    Modify and uncomment the following lines
       REM    to override the base/configure/CONFIG_ENV defaults
       REM set EPICS_CA_ADDR_LIST=n.n.n.n  n.n.n.n
       REM set EPICS_CA_AUTO_ADDR_LIST=YES
       REM set EPICS_CA_CONN_TMO=30.0
       REM set EPICS_CA_BEACON_PERIOD=15.0
       REM set EPICS_CA_REPEATER_PORT=5065
       REM set EPICS_CA_SERVER_PORT=5064
       REM set EPICS_TS_MIN_WEST=420
       REM --------------- JAVA ---------------------------------
       REM    Needed for java extensions
       REM set CLASSPATH=G:\epics\extensions\javalib
       REM set PATH=%PATH%;C:\j2sdk1.4.1_01\bin
       REM set CLASSPATH=%CLASSPATH%;C:\j2sdk1.4.1_01\lib\tools.jar
       REM --------------- Exceed -------------------------------
       REM    Needed for X11 extensions
       REM set EX_VER=7.10
       REM set EX_VER=12.00
       REM set EX_VER=14.00
       REM set PATH=%PATH%;C:\Exceed%EX_VER%\XDK\
       REM set PATH=%PATH%;C:\Program Files\Hummingbird\Connectivity\%EX_VER%\Exceed\
       Didn't change anything else. I think I missed something. What do you think I've missed?
       Thank you.
       Sincerely,
       Pavel Maslov, MSc
       R&D Institute for Electro-Physical Apparatus
       Mobile: +7 (951) 672 22 19
       Phone: +7 (812) 461 01 01
       Sincerely,
       Pavel Maslov, MSc
       Sincerely,
       Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Re: [help] EPICS build no good Geoff Savage
[help] EPICS build no good Pavel Masloff
RE: [help] EPICS build no good Mark Rivers
Re: [help] EPICS build no good Pavel Masloff
Prev: Re: problem using shell command in EDM Maurizio Montis
Next: Re: [help] EPICS build no good Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [help] EPICS build no good Pavel Masloff
