Hi Dirk,
first of all thanks for the answer.
following your suggestion i created a simple script and it works. It's
only a bit strange that the external script works while the "internal"
one didn't...commands and macro substitutions are equal.
- Maurizio
On Dec 05, 2011 04:12 PM, Dirk Zimoch <[email protected]> wrote:
> Hi Maurizio,
> What about a shell script that calls the web page? Only pass the
> parameters ADDR, ARCH, PV1 and YLAB and let the script build the URL.
> Dirk
> Maurizio Montis wrote:
> > Hello!
> > i'm developing a new EDM control panel to manage a quite complex
> > apparatus and i have a problem: i want to call my archiver web
> > interface
> > through the shell command control button, but my address is too much
> > long for the shell command field.
> > I'm trying to use macro substitutions to reduce the number of
> > characters
> > used in that field, but i didn't have the result desired yet.
> > In my case i'm interested to recall the following address:
> > $(ADDR)=$(ARCH)&PATTERN=*&GLOB=ON&LIST=RFQ%3ACMOD01_SG01%3AP&NAMES=RFQ%3A$(PV1)%3AP%0D%0A&STRSTART=1&STARTSTR=2H&STREND=1&ENDSTR=now&COMMAND=Plot&Y10=0&Y11=0&Y20=0&Y21=0&YLABEL=$(YLAB)&WIDTH=800&HEIGHT=600&SCALE=100&INTERPOL=0&INTTYPE=LINEAR&GAP=0&GAP2=0
> > where ADDR, ARCH, PV1 and YLAB are macros; in this way i can use it
> > in
> > my shell command field, but i'm not able to show the webpage desired
> > (and the macro substitution is correct, i checked).
> > Is there some particular option or configuration that i forget to
> > use?
> > Thank in advance for any help
> > - Maurizio
- problem using shell command in EDM Maurizio Montis
- Re: problem using shell command in EDM Dirk Zimoch
Re: [help] EPICS build no good Pavel Masloff
<2011>
2025
2026
BACnet for EPICS is available now. Webb, Steven B.
<2011>
2025
2026
