1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem using shell command in EDM
To: [email protected]
Date: Mon, 5 Dec 2011 15:54:33 +0100 (CET)
Hello!
i'm developing a new EDM control panel to manage a quite complex
apparatus and i have a problem: i want to call my archiver web interface
through the shell command control button, but my address is too much
long for the shell command field.
I'm trying to use macro substitutions to reduce the number of characters
used in that field, but i didn't have the result desired yet.
In my case i'm interested to recall the following address:
$(ADDR)=$(ARCH)&PATTERN=*&GLOB=ON&LIST=RFQ%3ACMOD01_SG01%3AP&NAMES=RFQ%3A$(PV1)%3AP%0D%0A&STRSTART=1&STARTSTR=2H&STREND=1&ENDSTR=now&COMMAND=Plot&Y10=0&Y11=0&Y20=0&Y21=0&YLABEL=$(YLAB)&WIDTH=800&HEIGHT=600&SCALE=100&INTERPOL=0&INTTYPE=LINEAR&GAP=0&GAP2=0
where ADDR, ARCH, PV1 and YLAB are macros; in this way i can use it in
my shell command field, but i'm not able to show the webpage desired
(and the macro substitution is correct, i checked).
Is there some particular option or configuration that i forget to use?
Thank in advance for any help
- Maurizio
Re: problem using shell command in EDM Dirk Zimoch
Prev: Re: EPICS Base 3.14.12.2-rc1 available for testing Dirk Zimoch
Next: Re: problem using shell command in EDM Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EDM Installation Error Allison, Stephanie
