1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EDM Installation Error
To: Ed Villasenor <[email protected]>, John William Sinclair <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 14 Dec 2011 08:41:59 -0800
Hi Ed,
This sounds like something discussed in these tech-talk messages:
http://www.aps.anl.gov/epics/tech-talk/2008/msg00356.php
http://www.aps.anl.gov/epics/tech-talk/2008/msg00357.php
We had the font init problem when upgrading to RHEL6 and applied the solution from msg00357.
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Ed Villasenor
> Sent: Tuesday, December 13, 2011 9:30 PM
> To: John William Sinclair; [email protected]
> Subject: Re: EDM Installation Error
> Dear John,
> I was able to compile edm by changing the const char to char.
> Unfortunately when I try to start EDM, "Font init failed - abort" error
> is displayed. Do you know if this error is related to the remFileOpen.cc
> file that I altered.
> Regards,
> Ed
> On Mon, 05 Dec 2011 09:33:26 -0500
> John William Sinclair <[email protected]> wrote:
> > Ed,
> > The problem is that some versions of g++ require a cast of the form
> > (const char *)
> > and others require (char *). Try editing the file and changing the
> > offending lines from
> > one of those forms to the other.
> > John Sinclair
> > Ed Villasenor wrote:
> > > Dear All,
> > > I'm currently installing EDM on a CentOS 6 laptop and came accross the
> > > same problem described here:
> > > hxxp://www.aps.anl.gov/epics/tech-talk/2010/msg00157.php
> > > and hxxp://www.aps.anl.gov/epics/tech-talk/2009/msg01681.php
> > > Has the solution for this problem been found?
> > > Additional Info
> > >  - EPICS Base: 3-14-11
> > >  - EDM: 1-11-2i
> > >  - installed
> > > 	epics base
> > > 	medm
> > > 	libpng-1 . 2 . 6rc1-config . tar . gz
> > > 	libungif-4 . 1 . 3 . tar . gz
> > > 	giflib-4 . 1 . 3 . tar . gz
> > > 	zlib-1 . 2 . 5 . tar . gz
> > > 	openmotif-2 . 3 . 3-1 . el4.5.i386.rpm
> > > 	openmotif-devel-2 . 3 . 3-1 . el4.5.i386.rpm
> > > I have previously installed EDM on a CentOS 5 Workstation without having
> > > this problem.
> > > Kind Regards,
EDM Installation Error Ed Villasenor
Re: EDM Installation Error Ed Villasenor
Prev: Re: Tektronix 3000/5000 oscilloscopes Pavel Masloff
Next: Re: synApps 5.6 release J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM Installation Error Ed Villasenor
Next: problem using shell command in EDM Maurizio Montis
