1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base 3.14.12.2-rc1 available for testing
To: Jeff Hill <[email protected]>
Cc: "'EPICS'" <[email protected]>
Date: Mon, 05 Dec 2011 11:25:39 +0100
I am going to guess that moving the "#include <ctime>" to be first in the
stack as follows might take care of this, and that this might be less of a
mess (messes accumulate) compared to interspersing the import from namespace
std into the middle of the #include list which might cause issues on other
compilers.
#include <ctime>
#include <cstddef>
#include <cstdio>
#include <cmath>
#include <climits>
#include <cstring>
We have, it seems, one of everything old here including an old Solaris
machine so I was trying to reproduce the issue here. The old perl upgrade
install on our old solaris is finally done. Now the EPICS R3.14 latest build
is failing I suspect because gnu make 3.79.1 is installed. Hopefully will
get this reproduced soon on Monday. However, if you can try the above idea
first it might be easier and faster.
The order of the include statements has no effect. What I did to solve the problem is to move the namespace import in front of all imports:
using namespace std;
#include <cstddef>
#include <cstdio>
#include <ctime>
#include <cmath>
#include <climits>
#include <cstring>
#include "epicsTime.h"
#include "epicsThread.h"
#include "errlog.h"
#include "epicsUnitTest.h"
#include "testMain.h"
Dirk
PS: Yes, the perl and make upgrade is a pain. That is exactly why I did not like the requirement for the new versions. One could also demand to upgrade to a newer C++ compiler, but then maybe EPICS libraries would not work together with the installed programs (e.g. EPICS-TCL interface).
EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
Re: EPICS Base 3.14.12.2-rc1 available for testing Dirk Zimoch
RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
Prev: Re: [help] EPICS build no good Pavel Masloff
Next: problem using shell command in EDM Maurizio Montis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
Next: Micro Research cPCI EVG support (request) Michael Davidsaver
