1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [help] EPICS build no good
To: Andrew Johnson <[email protected]>, Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Mon, 5 Dec 2011 22:32:19 +0300
Hey Andrew!!! Hi Dirk!
It worked :))
This was my first introduction to Epics. Andrew, Dirk, guys! What would you recommend me to do next? I mean, we have a Tektronix oscilloscope at work, namely TDS 5054, I guess. And I've read there's a driver written to hook it up to EPICS. How can I do it? Perhaps, I could try your PLC driver, Dirk as the next step in mastering Epics. What do you guys think?
Paul
On Mon, Dec 5, 2011 at 9:42 PM, Andrew Johnson <[email protected]> wrote:
Hi Pavel,
On 2011-12-05 Pavel Masloff wrote:
> D:\>softIoc -h
> Usage: softIoc [-D softIoc.dbd] [-h] [-S] [-a ascf]
>         [-m macro=value,macro2=value2] [-d file.db]
>         [-x prefix] [st.cmd]
> Compiled-in path to softIoc.dbd is:
>         'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
Forget my last message, the quotes are coming from this Makefile rule:
epicsInstallDir.h:
       $(ECHO) "FINAL_LOCATION=$(FINAL_LOCATION)"
       $(PERL) ../makeInstallDir.pl '$(FINAL_LOCATION)' > $@
On Unix the shell strips out those single quotes, but evidently yours is not
doing so (my win32-x86-mingw build does strip them, but not my win32-x86
build).  You can add two lines to the base/src/softIoc/makeInstallDir.pl file
to fix this:
=== modified file 'src/softIoc/makeInstallDir.pl'
--- src/softIoc/makeInstallDir.pl       2010-09-27 22:42:42 +0000
+++ src/softIoc/makeInstallDir.pl       2011-12-05 18:33:24 +0000
@@ -14,6 +14,8 @@
 my $path = shift;
 $path =~ s/\\/\\\\/gx;
+$path =~ s/^'//x;
+$path =~ s/'$//x;
 print "/* THIS IS A GENERATED FILE. DO NOT EDIT! */\n",
      "\n",
I will add this change to the 3.14.12.2 release of Base.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Re: [help] EPICS build no good Dirk Zimoch
[help] EPICS build no good Pavel Masloff
Re: [help] EPICS build no good Andrew Johnson
Re: [help] EPICS build no good Pavel Masloff
Prev: Re: [help] EPICS build no good Andrew Johnson
Next: synApps 5.6 release Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [help] EPICS build no good Dirk Zimoch
