1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unbalanced conditional ?
To: [email protected]
Date: Thu, 8 Dec 2011 11:18:52 -0600
Hi Dirk,
On 2011-12-08 Dirk Zimoch wrote:
> > When I tried to upgrade from 3.14.8 to 3.14.12, I found that some CALC
> > expressions are not working any more, e.g. "B=0?A"
> > In 3.14.8 and all previous versions that meant: If B is 0 then set VAL
> > to A otherwise don't change VAL.
> > Now, I get the error message:
> > Unbalanced conditional ?: operators in CALC expression 'B=0?A'
> > Can't set "recordname.CALC" to "B=0?A"
> > Was there any good reason for this incompatible change in the CALC
> > behavior?
Yes, it was really obscure; I didn't know it worked at the time, let alone
that it was documented.  There was certainly nothing in the code to indicate
that it was meant to be legal.
You can add ":VAL" to fix old expressions, which in 3.14.12 and later can be
up to 79 characters long.
> The change is not mentioned in the release notes
> http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
> Thus I guess the new behavior was not intended and is a bug.
The change was part of a major rewrite of the CALC expression parser that was
released as part of 3.14.9 in 2007.  Making this legal again would IMHO be a
backwards step since there is an easy fix for old expressions and the results
are easier to understand.
Sorry, that's just another change you'll have to make when upgrading.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: Unbalanced conditional ? Dirk Zimoch
Prev: Re: Unbalanced conditional ? Dirk Zimoch
Next: Re: [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Unbalanced conditional ? Dirk Zimoch
