THANKS MIROSLAV!!!
It worked. The base is installed now at long last. Any idea on how to use EPICS? I started with softIoc and then iocInit. Which were both ok. After that i run exit. I am planning to hook up a Tektronix 3054 oscillograph. But hesitate for some reason. Do not know where to start.
Thank you very much! You helped a lot!
Pavel
On Thu, Dec 8, 2011 at 10:45 PM, Miroslav Mihaylov <[email protected]> wrote:
Hello.
I am new to epics as well but maybe I can save you some of the troubles I went
trough during the installation on linux .
These are my personal notes for the EPICS installation.
http://miro.phy.uic.edu/index.php?option=com_content&view=article&id=52&Itemid=83&lang=en
In general for linux you need to setup the EPICS environment variables.
One way of doing that is via the file ~/.bashrc
Here is the content of my bashrc file.
EPICS_HOST_ARCH=linux-x86_64
EPICS_BASE$HOME/EPICS/BASE
EPICS_DISPLAY_PATH=$HOME/EPICS/synApps/support/all_adl/
LD_LIBRARY_PATH=$HOME/EPICS/BASE/lib/linux-x86_64
PATH=$PATH:$HOME/bin:$HOME/EPICS/BASE/bin/linux-x86_64:
$HOME/EPICS/extensions/bin/linux-x86_64/:/usr/local/bin
I could help you with the epics installation for the redhat.
export EPICS_HOST_ARCH
export EPICS_BASE
export PATH
export EPICS_DISPLAY_PATH
export LD_LIBRARY_PATH
For BASE you will need those packages.
yum install perl-devel readline-devel gcc-c++
Also for RedHat 5 you need to use the ncurses instead of the readline libraly.
So in the file
~/EPICS/BASE/configure/os/CONFIG_SITE.Common.linux-x86 or
CONFIG_SITE.Common.linux-x86_64
comment the line refering to readline and uncoment the ncurses.
# No other libraries needed (recent Fedora, Ubuntu etc.):
#COMMANDLINE_LIBRARY = READLINE
# Needs -lncurses (RHEL 5 etc.):
COMMANDLINE_LIBRARY = READLINE_NCURSES
Don't forget to run
make clean
before
make install
Also don't forget that the changes made to bashrc do not take in effect until
the next login.
Let me know if this worked for you.
Miroslav
On Thursday 08 December 2011 04:02:08 Pavel Masloff wrote:
> Hello everyone!
> How can I set the environment variables (PATH and EPICS_HOST_ARCH) in
> RHEL-5 64 bit?
> I ran the EpicsHostArch.pl script (>> perl EpicsHostArch.pl), but this
> script only returns the variable, doesn't set anything. I check by running
> "dev" in the command line.
> And generally, what should one do to install the epics base from scratch on
> a linux machine?
> Thanks.
> Pavel.
Miroslav Mihaylov
University of Illinois at Chicago
Department of Physics
2336 SES
845 W. Taylor St. M/C 273
Chicago, IL 60607
312 355 0225
-- Sincerely,
Pavel Maslov, MSc R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
- [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
Re: Unbalanced conditional ? Andrew Johnson
Re: Unbalanced conditional ? Dirk Zimoch
<2011>
2025
2026
Re: [building EPICS in RHEL-5 64bit] environment variables Alan Greer
About the interface LabCA problem that Matlab can't read image data from areaDetector 的
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
