1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [building EPICS in RHEL-5 64bit] environment variables
To: Pavel Masloff <[email protected]>
Cc: [email protected]
Date: Thu, 08 Dec 2011 11:46:08 +0000
I would recommend a visit to the EPICS site.
http://www.aps.anl.gov/epics/extensions/index.php
http://www.aps.anl.gov/epics/docs/GSWE.php
Pavel Masloff wrote:
btw what's extensions?
On Thu, Dec 8, 2011 at 2:40 PM, Alan Greer <[email protected] <mailto:[email protected]>> wrote:
    Pavel,
    I just noticed you are building for 64 bit so you don't want
    EPICS_HOST_ARCH=linux-x86 you probably want
    EPICS_HOST_ARCH=linux-x86_64
    Sorry about that.
    Alan Greer wrote:
        OK, then to install base I would do something like the following:
        Setup a BASE location export
        export BASE=/path/to/base
        (Be warned I use "rm -rf" in places below as I have lifted
        this from a script.  This is a recursive forced remove and
        could potentially delete many files).
        The lines below basically unpack the source code into two
        subdirectories base and extensions.  I would set BASE to
        something like
        export BASE=~/applications/epics/R3-14-12-1
        Then enter the following lines (or run from a script)
         rm -rf $BASE/base
         cp ./baseR3.14.12.1.tar.gz $BASE/baseR3.14.12.1.tar.gz
         gunzip $BASE/baseR3.14.12.1.tar.gz
         tar -xvf $BASE/baseR3.14.12.1.tar -C $BASE
         rm -f $BASE/baseR3.14.12.1.tar
         mv $BASE/base-3.14.12.1 $BASE/base
         # Unpack the extensions sources
         cp ./extensionsTop_20070703.tar.gz
        $BASE/extensionsTop_20070703.tar.gz
         gunzip $BASE/extensionsTop_20070703.tar.gz
         tar -xvf $BASE/extensionsTop_20070703.tar -C $BASE
         rm -f $BASE/extensionsTop_20070703.tar
         # Update the EXTENSION_MSI link in the Makefile
         sed "s/^EXTENSION_MSI.*/EXTENSION_MSI = msi1-5/"
        $BASE/extensions/src/Makefile > Makefile.tmp
         mv Makefile.tmp $BASE/extensions/src/Makefile
         # Unpack the msi extension sources
         cp ./msi1-5.tar.gz $BASE/extensions/src/msi1-5.tar.gz
         gunzip $BASE/extensions/src/msi1-5.tar.gz
         tar -xvf $BASE/extensions/src/msi1-5.tar -C $BASE/extensions/src
         rm $BASE/extensions/src/msi1-5.tar
        The files I used above are
        msi1-5.tar.gz
        Then...
        # Export the required variables
        export EPICS_BASE=$BASE/base
        export EPICS_HOST_ARCH=linux-x86
        export PATH=$PATH:$EPICS_BASE/bin/linux-x86
        export PATH=$PATH:$EPICS_BASE/../extensions/bin/linux-x86
         cd $BASE/base
         make
         make install
         cd $BASE/extensions
         make
         make install
        I'm sure there are better instructions in the many manuals and
        tutorials that exist for EPICS.
            Thanks, I'd figured this already :))
            On Thu, Dec 8, 2011 at 1:19 PM, Alan Greer
            <[email protected]
            <mailto:[email protected]>>> wrote:
               [ajg@osllx10 ~]$ export PATH=/temp/path
               [ajg@osllx10 ~]$ echo $PATH
               /temp/path
               [ajg@osllx10 ~]$
               [ajg@osllx10 ~]$ export EPICS_HOST_ARCH=linux-x86
               [ajg@osllx10 ~]$ echo $EPICS_HOST_ARCH
               linux-x86
               [ajg@osllx10 ~]$
                   Hello everyone!
                   How can I set the environment variables (PATH and
                   EPICS_HOST_ARCH) in RHEL-5 64 bit?
                   I ran the EpicsHostArch.pl script (>> perl
            EpicsHostArch.pl),
                   but this script only returns the variable, doesn't set
                   anything. I check by running "dev" in the command line.
                   And generally, what should one do to install the
            epics base
                   from scratch on a linux machine?
                   Thanks.
                   Pavel.
                   --         Sincerely,
                   Pavel Maslov, MSc
                   R&D Institute for Electro-Physical Apparatus
                   Mobile: +7 (951) 672 22 19
                   Phone: +7 (812) 461 01 01
-- Sincerely,
            Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
[building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
Re: [building EPICS in RHEL-5 64bit] environment variables Alan Greer
Re: [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
Prev: Re: [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
Next: Re: [building EPICS in RHEL-5 64bit] environment variables Alan Greer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [building EPICS in RHEL-5 64bit] environment variables Alan Greer
Next: Re: [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
