1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: About the interface LabCA problem that Matlab can't read image data from areaDetector
To: [email protected]
Date: Sat, 10 Dec 2011 20:14:38 +0800 (CST)
Hi everbody
   I used procilica camera to read image data in EPICS. And use LabCA as interface to link Matlab and areaDetector based in EPICS. So I met this problem. Maybe the Channel Access interface only supports reading arrays as doubles (64-bit floating points), but the Prosilica is normally sending 8-bit data. Thus when I use Matlab to read image datas, Matlab would shut up automatically. Or that is the other question? Does anyone met this question? And how to solve it ?
    Thank you !
        !          Peng
RE: About the interface LabCA problem that Matlab can't read image datafrom areaDetector Mark Rivers
Re: About the interface LabCA problem that Matlab can't read image data from areaDetector Till Straumann
Prev: Re: Unbalanced conditional ? Dirk Zimoch
Next: RE: About the interface LabCA problem that Matlab can't read image datafrom areaDetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
