1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: About the interface LabCA problem that Matlab can't read image data from areaDetector
To: [email protected], [email protected]
Date: Mon, 12 Dec 2011 10:11:40 -0600
Hi.
If you want to get help then you should provide more detailed information.
By just saying that you 'met this problem' and 'matlab would shut up automatically'
you are not really giving us a clear picture of what you were experiencing.
If you ask for help then it is always a good idea to submit an *unedited* console
log of your session. Please do not edit anything away since valuable clues
are often at a place where you wouldn't expect them.
A very vague request for help ("it doesn't work, please help") is more likely
to not being answered as it generates more work for the expert(s) since they
usually have to write an email like this one prior to being able to help.
Regards
- Till
On 12/10/2011 06:14 AM, 的 wrote:
Hi everbody
   I used procilica camera to read image data in EPICS. And use LabCA as interface to link Matlab and areaDetector based in EPICS. So I met this problem. Maybe the Channel Access interface only supports reading arrays as doubles (64-bit floating points), but the Prosilica is normally sending 8-bit data. Thus when I use Matlab to read image datas, Matlab would shut up automatically. Or that is the other question? Does anyone met this question? And how to solve it ?
    Thank you !
        & nbsp; !          Peng
Prev: Re: About the interface LabCA problem that Matlab can't read image data from areaDetector Till Straumann
Next: Re: Tektronix 3000/5000 oscilloscopes Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: pyepics3 Stripchart howto wanted Peter Milne
