1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics base 3.14.12.1 build error on fedora 16
To: "Pavel Masloff" <[email protected]>
Date: 16 Dec 2011 11:39:19 +0100
Hello Pavel,
I had the same problems on Fedora15. I used these two patches to fix the problems.
Best regards,
Florian
On 12/16/2011 11:31 AM, Pavel Masloff wrote:
Hello Miroslav!
I have experienced the same problem you had - http://www.aps.anl.gov/epics/tech-talk/2011/msg00964.php
How did you resolve it? I have changed "size_t _refCount;" to "std :: size_t _refCount;" in epicsSingleton.h as was proposed. But still I get this:
In file included from ../cac.cpp:39:0:
../cac.h:269:26: error: reference ‘mutex’ cannot be declared ‘mutable’
[-fpermissive]
../cac.h:270:26: error: reference ‘cbMutex’ cannot be declared ‘mutable’
[-fpermissive]
In file included from ../cac.cpp:47:0:
../udpiiu.h:152:26: error: reference ‘cbMutex’ cannot be declared
‘mutable’ [-fpermissive]
../udpiiu.h:153:26: error: reference ‘cacMutex’ cannot be declared
make[3]: *** [cac.o] Error 1
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
| Florian Feldbauer                 |
| Ph.D. student                     |
| Institut für Experimentalphysik I |
| Ruhr-Universität Bochum           |
| Universitätsstr. 150              |
| D-44780 Bochum                    |
| Office: NB 2/173                  |
| Phone:  (+49)234 / 32-23538       |
| Fax:    (+49)234 / 32-14170       |
| Web:    http://www.ep1.rub.de     |
>From 86968a0af746bfbb2108f5342c83a8293edae957 Mon Sep 17 00:00:00 2001
Date: Tue, 31 May 2011 08:40:01 -0400
Subject: Drop "mutable" references
It doesn't appear that any code is attempting
to actually change them...
 src/ca/cac.h    |    4 ++--
 src/ca/udpiiu.h |    4 ++--
 src/db/dbCAC.h  |    4 ++--
 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git src/ca/cac.h src/ca/cac.h
index 4bac0cd..ae20eef 100644
--- src/ca/cac.h
+++ src/ca/cac.h
@@ -266,8 +266,8 @@ private:
     // **** lock hierarchy ****
     // 1) callback lock must always be acquired before
     // the primary mutex if both locks are needed
-    mutable epicsMutex & mutex;
-    mutable epicsMutex & cbMutex;
+    epicsMutex & mutex;
+    epicsMutex & cbMutex;
     epicsEvent iiuUninstall;
     ipAddrToAsciiEngine & ipToAEngine;
     epicsTimerQueueActive & timerQueue;
diff --git src/ca/udpiiu.h src/ca/udpiiu.h
index 0f3d1a3..3c93275 100644
--- src/ca/udpiiu.h
+++ src/ca/udpiiu.h
@@ -149,8 +149,8 @@ private:
     double rtteMean;
     double rtteMeanDev;
     cac & cacRef;
-    mutable epicsMutex & cacMutex;
+    epicsMutex & cacMutex;
     epics_auto_ptr < epics_auto_ptr < class searchTimer >, eapt_array > ppSearchTmr;
     unsigned nBytesInXmitBuf;
     unsigned nTimers;
diff --git src/db/dbCAC.h src/db/dbCAC.h
index b25fe30..3032023 100644
--- src/db/dbCAC.h
+++ src/db/dbCAC.h
@@ -196,8 +196,8 @@ private:
     dbContextReadNotifyCache readNotifyCache;
     dbEventCtx ctx;
     unsigned long stateNotifyCacheSize;
     cacContextNotify & notify;
     epics_auto_ptr < cacContext > pNetContext;
     char * pStateNotifyCache;
1.7.3.4
diff -rc base-3.14.12.1/src/libCom/cxxTemplates/epicsSingleton.h new-3.14.12.1/src/libCom/cxxTemplates/epicsSingleton.h
*** base-3.14.12.1/src/libCom/cxxTemplates/epicsSingleton.h	Tue Apr 26 22:40:09 2011
--- new-3.14.12.1/src/libCom/cxxTemplates/epicsSingleton.h	Mon Aug  8 18:07:58 2011
*** 34,40 ****
      void * pInstance () const;
  private:
      void * _pInstance;
!     size_t _refCount;
      SingletonUntyped ( const SingletonUntyped & );
      SingletonUntyped & operator = ( const SingletonUntyped & );
--- 34,40 ----
  private:
      void * _pInstance;
!     std :: size_t _refCount;
Re: epics base 3.14.12.1 build error on fedora 16 Pavel Masloff
Prev: epics base 3.14.12.1 build error on fedora 16 Pavel Masloff
Next: Re: epics base 3.14.12.1 build error on fedora 16 Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
