Hi Pavel,
> Can one install the EPICS IDE plugin _locally_? I mean, download the
> *.jars and install the same way as installing CDT?
Yes, that should be possible. But this is not recommended because you
have to deal with a lot of dependencies etc.
> I am provided only through a Virtual Machine (run on
> the same pc), which has a limited number of applications (I guess this
> is done due to security purposes - against viruses, trojans, etc). So
> there is no direct connection :(
If you just want to give Control System Studio a try you can start by
downloading a product for another machine - e.g. NSLS-II:
http://cs-studio.sourceforge.net/ This way you only have to copy one
file to your machine. The downside is that some settings might be wrong
for your machine - but you can fix that afterwards. If you want your own
combination of plug-ins or your own site-specific settings on several
machines you should think about creating your own CSS product (see
http://cs-studio.sourceforge.net/docbook/index.html for details).
Cheers
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
- Re: [Eclipse] EPICS IDE plugin Pavel Masloff
- [Eclipse] EPICS IDE plugin Pavel Masloff
Re: Problem with msi rules in R3.14.12.2 Eric Norum
Re: [Eclipse] EPICS IDE plugin Andrew Johnson
<2011>
2025
2026
<2011>
2025
2026
