1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: application build error with new sequence program
Cc: [email protected]
Date: Wed, 21 Dec 2011 18:46:44 -0600 (CST)
Problem solved - I had a fat-finger incident in my Makefile.
Lessons learned? don't comment out the following line:
   sncProgram_SRCS += sncProgram.st
Nothing more to see here, move along :)
Have a great holiday break everyone!
--J
----- Original Message -----
To: "S. Stein" <[email protected]>, [email protected]
Sent: Wednesday, December 21, 2011 4:30:29 PM
Subject: RE: application build error with new sequence program
Is your sequencer calling some functions from another library?  How do the link commands that EPICS is generating compare for your sequencer and the example sequencer?
Sent: Wed 12/21/2011 4:26 PM
To: [email protected]
Subject: application build error with new sequence program
Greetings,
  I have a minGW build of epics 3.14.12.1 - and using an older version of the sequencer (I haven't been able to try Benjamin's fix for the newest release yet). I have built and run the example sequence, and now am replacing that one with my own. When I do a 'make' I get the following error:
g++ -o sncProgram.exe  -LC:\Users\Josh\base-3.14.12.1\lib\win32-x86-mingw -LC:\Users\Josh\seq-2.
0.14\lib\win32-x86-mingw       -m32               scaStartup.o    -lseq -lpv -lcas -lgdd -lasHos
t -ldbStaticHost -lregistryIoc -lca -lCom
c:/mingw/bin/../lib/gcc/mingw32/4.6.1/../../../libmingw32.a(main.o): In function `main':
C:\MinGW\msys\1.0\src\mingwrt/../mingw/main.c:73: undefined reference to `WinMain@16'
collect2: ld returned 1 exit status
make[2]: *** [sncProgram.exe] Error 1
I verified that the application will build fine when I point the Makefile back to the example sequence program, so it seems isolated to my new sequence; however I can see nothing peculiar in that .stt file. Has anyone seen this creep up before and can offer the simple "just add this" solution?
--Josh
RE: application build error with new sequence program Mark Rivers
Prev: RE: application build error with new sequence program Mark Rivers
Next: Australian Synchrotron Employment Opportunities Controls Lou Corvetti
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
