Subject: Re: Peculiar SNL behaviour
To: "S. Stein" <[email protected]>
Cc: [email protected]
Date: Tue, 3 Jan 2012 10:12:52 -0800
seqFlag should be an event, ie, type evflag, and should be set with efSet and examined with efTest[AndClear].  I've put that in your example below.   When clauses do not poll but are triggered by events.  evflag settings are events, as are changes to PVs, but  changes of variables are not.
Carl
On Sat, Dec 31, 2011 at 3:43 PM, S. Stein <[email protected]> wrote:
Last question for 2011 from me - I promise!
I have a sequence program with a couple of state sets running. To enable a state transition in one state-set, I set (or reset) a variable (which does not correspond to an EPICS PV) - see example below. here is my issue: I cannot seem to get the 'wait' state in stateset 2 to fire off without toggling 'pv1'.
Here's what I do: assuming the PV  'epics:pv1C' is set to a BO record, I run the IOC. I see the console messages for the state sets firing off. I then set the VAL of 'epics:pv1C' to '1' and see that the ioc console responds with "PV Change state". After 2 seconds delay the internal variable 'seqFlag' is set to true, which _should_ (at least I think) fire off the 'wait' state in the second set, thus printing "Wait State Reached" on the IOC console. It does not. I have to set the PV 'epics:pv1C' to '0' and back to '1' to get the state transition to fire.
I don't think this behavior is appropriate - what say the community?
Contrived example:
/* epics variables */
short pv1; assign pv1 to "epics:pv1C"; monitor pv1;
/* sequencer variables */
evflag seqFlag;
ss set1 {
 state init {
 entry {
  printf("Set 1 started\n");
 when (pv1 == TRUE);{
  printf("PV Change state\n");
  } state seqHold
 state seqHold {
 when(delay(2)) {
  efSet(seqFlag);
 } state done
 state done {
 when(FALSE) {
 } state init
ss set2 {
 state init {
 when(Delay(1){
  printf("Set 2 started\n");
 } state wait
 state wait {
 when ((pv1 == TRUE) && efTestAndClear(seqFlag)) {
  printf("'Wait state' reached\n");
 } state done
 state done {
 when(FALSE) {
 } state init
Carl Lionberger
Controls Software Engineer
LBNL Engineering Division
510 486 7503
Prev: Re: Peculiar SNL behaviour Eric Norum
Next: Re: Peculiar SNL behaviour Tim Mooney
