1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: autosave application loading error
To: "Williams Jr., Ernest L." <[email protected]>, "tech-talk" <[email protected]>
Date: Wed, 4 Jan 2012 15:24:43 +0800
That's resolve the problem.
Thank you!
Zhang Yuliang
发件人: Williams Jr., Ernest L.
发送时间: 2012-01-04  11:51:06
收件人: Zhang Yuliang
抄送: tech-talk
主题: Re: autosave application loading error
Please add nfs support to your vxWorks kernel image
That should resolve your problem
Cheers
Ernest
Sent from my iPhone
On Jan 3, 2012, at 18:23, "Zhang Yuliang" <[email protected]<mailto:[email protected]>> wrote:
Hi All,
Recently I tried to use autosave Module and I downloaded autosave_R4-4.  I created a new EPICS application named asApp, and successfully built the application following the build step in the documention mentioned in "autoSaveRestore.html" . When I load the EPICS application to target VEM5100, the error occured:
ld < asApp.munch
Undefined symbol: nfsMount (binding 1 type 0)
Undefined symbol: nfsUnmount (binding 1 type 0)
ld error: Module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
The related software I am using is: EPICS Base-3.14.8.2, vxWorks5.5.1(Tornado 2.2.1).
Thank you !
Zhang Yuliang
autosave application loading error Zhang Yuliang
Re: autosave application loading error Williams Jr., Ernest L.
Prev: Re: RTEMS-MVME2300 Eric Norum
Next: assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: autosave application loading error Williams Jr., Ernest L.
Next: Re: RTEMS-MVME2300 Michael Davidsaver
