Subject: RE: Building base-3.14.12.2 on windows-x64
To: "'John Dobbins'" <[email protected]>, "'Mark Rivers'" <[email protected]>, "'EPICS Tech-Talk'" <[email protected]>
Date: Wed, 4 Jan 2012 16:57:12 -0700
> I think Jeff Hill also had trouble recently with the mingw version of
> make, but had success with GnuWin32.
Yes, I have also experienced this issue and found that only a very special
version of mingw gnu make works (maybe not even every 3.81 tagged version
works as I recall)...
>gmake --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i386-pc-mingw32
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of John Dobbins
> Sent: Wednesday, January 04, 2012 10:55 AM
> To: Mark Rivers; EPICS Tech-Talk
> That worked! I switched to the  GnuWin32 version of make and was able to
> build. Thanks Mark!
> John Dobbins
> From: Mark Rivers [[email protected]]
> Sent: Wednesday, January 04, 2012 12:02 PM
> To: John Dobbins; EPICS Tech-Talk
> John,
> I would recommend using GnuWin32 version of make instead. It is working
> fine for me.
> http://gnuwin32.sourceforge.net/packages/make.htm
> I am using ActivePerl and Visual Studio 2008.
> Mark
> Sent: Wednesday, January 04, 2012 10:53 AM
> To: EPICS Tech-Talk
> Subject: Building base-3.14.12.2 on windows-x64
> All,
> I am attempting to build EPICS3.14.12.2  on windows-x64 for the first
> time. I should add that the entire Windows7/x64 environment is new to me.
> Windows 7 x64
> Visual Studio 2010
> mingw-make = GNU Make 3,82 built for i386-pc-mingw32
> perl = 5.14.2 built for MSWIN32-x64-multi-thread
> What I did:
> 1) set environment variable  EPICS_HOST_ARCH = windows-x64
> 2) set-up environment via   "vcvarsall.bat amd64"
> (I haven't changed anything else in configure/ )
> then do mingw32-make in top level directory. I run into trouble the first
> time the linker is called, see below. Can someone tell me what I have
> missed?
> Thanks,
> John Dobbins
> link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
> /release /ve
> rsion:3.14  /MACHINE:X64    /implib:com.lib /out:com.dll
> bucketLib.obj ep
> icsRingPointer.obj epicsRingBytes.obj postfix.obj calcPerform.obj
> cvtFast.obj re
> sourceLib.obj epicsOnce.obj epicsSingletonMutex.obj dbmf.obj ellLib.obj
> envSubr.
> obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj fdmgr.obj
> fdManager.obj f
> reeListLib.obj gpHashLib.obj iocsh.obj registry.obj libComRegister.obj
> iocLog.ob
> j logClient.obj macCore.obj macEnv.obj macUtil.obj aToIPAddr.obj
> adjustment.obj
> cantProceed.obj epicsConvert.obj epicsExit.obj epicsStdlib.obj
> epicsString.obj t
> runcateFile.obj ipAddrToAsciiAsynchronous.obj epicsUnitTest.obj
> epicsThread.obj
> epicsMutex.obj epicsEvent.obj epicsTime.obj epicsMessageQueue.obj
> epicsMath.obj
> epicsGeneralTime.obj osiClockTime.obj osdSock.obj osdSockAddrReuse.obj
> osiSock.o
> bj systemCallIntMech.obj epicsSocketConvertErrnoToString.obj osdAssert.obj
> osdFi
> ndSymbol.obj osdInterrupt.obj osdPoolStatus.obj osdSignal.obj osdEnv.obj
> epicsRe
> adline.obj epicsTempFile.obj epicsStdio.obj osdStdio.obj osdThread.obj
> osdMutex.
> obj osdEvent.obj osdTime.obj osdProcess.obj osdNetIntf.obj
> osdMessageQueue.obj d
> evLibVME.obj devLibVMEOSD.obj taskwd.obj epicsTimer.obj timer.obj
> timerQueue.obj
>  timerQueueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj
> tsDefs.obj e
> picsGetopt.obj setThreadName.obj forceBadAllocException.obj
>    Creating library com.lib and object com.exp
> fdManager.obj : error LNK2001: unresolved external symbol __WSAFDIsSet
> __imp_WSAGetLastError
> fdManager.obj : error LNK2001: unresolved external symbol __imp_select
> logClient.obj : error LNK2001: unresolved external symbol __imp_send
> logClient.obj : error LNK2001: unresolved external symbol __imp_setsockopt
> logClient.obj : error LNK2001: unresolved external symbol __imp_shutdown
> logClient.obj : error LNK2001: unresolved external symbol __imp_htons
> logClient.obj : error LNK2001: unresolved external symbol __imp_connect
> aToIPAddr.obj : error LNK2001: unresolved external symbol __imp_htonl
> osdSock.obj : error LNK2001: unresolved external symbol __imp_accept
> __imp_gethostbyname
> __imp_gethostbyaddr
> osdSock.obj : error LNK2001: unresolved external symbol __imp_closesocket
> osdSock.obj : error LNK2001: unresolved external symbol __imp_socket
> osdSock.obj : error LNK2001: unresolved external symbol __imp_WSACleanup
> osdSock.obj : error LNK2001: unresolved external symbol __imp_WSAStartup
> osiSock.obj : error LNK2001: unresolved external symbol __imp_ntohs
> osiSock.obj : error LNK2001: unresolved external symbol __imp_ntohl
> osdProcess.obj : error LNK2001: unresolved external symbol
> __imp_MessageBoxA
> __imp_GetUserNameA
> osdNetIntf.obj : error LNK2001: unresolved external symbol __imp_WSAIoctl
> com.dll : fatal error LNK1120: 21 unresolved externals
> mingw32-make[3]: *** [Com.dll] Error 1120
> mingw32-make[3]: Leaving directory `X:/winDev/epics/R3.14.12/base-
> 3.14.12.2/src/
> libCom/O.windows-x64'
> mingw32-make[2]: *** [install.windows-x64] Error 2
> mingw32-make[2]: Leaving directory `X:/winDev/epics/R3.14.12/base-
> 3.14.12.2/src/
> libCom'
> mingw32-make[1]: *** [libCom.install] Error 2
> mingw32-make[1]: Leaving directory `X:/winDev/epics/R3.14.12/base-
> 3.14.12.2/src'
> mingw32-make: *** [src.install] Error 2
Building base-3.14.12.2 on windows-x64 John Dobbins
RE: Building base-3.14.12.2 on windows-x64 John Dobbins
Prev: RE: assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 Jeff Hill
Next: RE: The crash of Matlab using LabCA Mark Rivers
Prev: RE: Building base-3.14.12.2 on windows-x64 John Dobbins
Next: RE: Building base-3.14.12.2 on windows-x64 Mark Rivers
