Subject: Announce: sequencer release 2.1.4
To: <[email protected]>
Date: Tue, 10 Jan 2012 14:20:09 +0100
Hi All
This is, again, a pure bug fix release.
As usual, documentation, release notes, download links, and install
instructions can be found on the sequencer homepage:
  http://tinyurl.com/epics-seq/
User relevant changes since 2.1.3 are:
* snc: fixed parser stack overflow
  This appeared when compiling deeply nested statements.
  The solution is to use a dynamically growing stack.
* pv: only install public interface header files
* pv: fixed a build problem on mingw32
  The solution is to use epicsShareClass on class
  declarations, instead of epicsShareFunc on methods.
* test: fix Makefile to allow building if sources are read-only
* docs: fixed some typos and a build problem with note:: directives
* configure: made 3.14.12.2 the default base release
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: CSS app Launcher Patard Charles Henri
Next: RE: CSS app Launcher Kasemir, Kay
Next: Re: pyepics: Strategies for working with fast-changing large arrays Anton Derbenev
