1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS app Launcher
To: "'Patard Charles Henri'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 10 Jan 2012 23:53:00 -0500
Hello:
Internally, the application launcher uses the Eclipse/SWT
  Program.launch()
command.
This is supposed to launch “the operating system executable associated with the file or URL”.
On Windows or OS X this means for example that your “command” can be
/Path/to/some/spreadsheet.xls
and it will open in Excel.
So I would look for the association of your executable file with in this case firefox somewhere in the operating system, outside of CSS.
What happens when you double click the file in some other file navigator?
I’m not even sure what OS you are using. Linux? Try the gnome or KDE file browser?
If all fails, you might have to create a shell script/batch file that opens your actual file in the desired tool,
and then enter the path to that shell script in the CSS app launcher.
Kay
From: [email protected] [mailto:[email protected]] On Behalf Of Patard Charles Henri
Sent: Tuesday, January 10, 2012 5:27 AM
To: [email protected]
Subject: CSS app Launcher
Hello All,
I'm trying to launch an executable file ada (bin file) with Application Launcher of CSS. I create a .app in a project and configure the .app like this :
<application>
      <command>./ctrol/execs/applications/choix/exec/choix</command>
      <icon>icon:work</icon>
</application>
When I run the .app file with the Application Launcher the Firefox Navigator open with this question :
" You have chosen to open choix which is a file type : bin file. Would you like to save it ? "
If I try the same thing with a .jar file, it's working good.
Thanks. Best regards.
Re: CSS app Launcher Patard Charles Henri
Prev: Announce: sequencer release 2.1.4 Benjamin Franksen
Next: Re: CSS app Launcher Patard Charles Henri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CSS app Launcher Patard Charles Henri
