Subject: Re: [CSS] 'Epics' menu in Preferences disappeared!!!
To: "Kasemir, Kay" <[email protected]>
Date: Fri, 27 Jan 2012 14:43:45 +0300
Kay,
One little question. When my CSS app is compiled to run on linux, the 'splash screen' (on CSS start-up) appears and I can see the plugins load, as well as the image with the CSS contributors (which is nice, as a matter of fact). When I run the same app on Windows (css.exe), the splash screen does NOT show up!!!
The same behavior is in the original CSS 3.0.1 from KEK!
Do you know what might be the reason?
Paul
PS
I have successfully built my CSS for linux, and it works absolutely wonderful.
On Wed, Jan 25, 2012 at 6:47 PM, Kasemir, Kay <[email protected]> wrote:
Hello Pavel:
>... Now it seems to me building your own application
> in Eclipse using features is not hard whatsoever.
> One just needs to include all the plugins required
> (as in Run->run as-> configurations).
I'm glad you see it that way.
Overall, it's not trivial, since the overall task
is similar to compiling and installing a comparable
set of the original EPICS client tools:
Decide if you want Probe, (M)EDM, StripTool, ALH, ...,
find suitable versions of Motif/Lesstif/OpenMotif,
then create some top-level launcher
(EDM "Main" page? tcl/tk or python/tk or ...?).
On the upside, once you get a CSS product assembled
for your site, it is quite easy to then "export" that
for Linux, Windows, OS X.
-Kay
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Prev: Re: odd behavior of 'dbpf' on windows softioc Andrew Johnson
Next: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Prev: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
