1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [CSS] 'Epics' menu in Preferences disappeared!!!
To: "Kasemir, Kay" <[email protected]>
Date: Fri, 27 Jan 2012 16:07:57 +0300
Answering my own question.
The truth is that the original KEK splash.bmp was a png file, renamed to bmp.
Somehow, Linux doesn't care, whereas it's critical to Windows.
Cheers,
Paul
On Fri, Jan 27, 2012 at 2:43 PM, Pavel Masloff <[email protected]> wrote:
Kay,
One little question. When my CSS app is compiled to run on linux, the 'splash screen' (on CSS start-up) appears and I can see the plugins load, as well as the image with the CSS contributors (which is nice, as a matter of fact). When I run the same app on Windows (css.exe), the splash screen does NOT show up!!!
The same behavior is in the original CSS 3.0.1 from KEK!
Do you know what might be the reason?
Paul
PS
I have successfully built my CSS for linux, and it works absolutely wonderful.
On Wed, Jan 25, 2012 at 6:47 PM, Kasemir, Kay <[email protected]> wrote:
Hello Pavel:
>... Now it seems to me building your own application
> in Eclipse using features is not hard whatsoever.
> One just needs to include all the plugins required
> (as in Run->run as-> configurations).
I'm glad you see it that way.
Overall, it's not trivial, since the overall task
is similar to compiling and installing a comparable
set of the original EPICS client tools:
Decide if you want Probe, (M)EDM, StripTool, ALH, ...,
find suitable versions of Motif/Lesstif/OpenMotif,
then create some top-level launcher
(EDM "Main" page? tcl/tk or python/tk or ...?).
On the upside, once you get a CSS product assembled
for your site, it is quite easy to then "export" that
for Linux, Windows, OS X.
-Kay
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Prev: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Next: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
