Hi John,
I am trying edm1-12-70 and I have discovered that the animated symbol class name changed from anaSymbolClass to aniSymbolClass.
Because I want to use the same edm screen files in both development and production environments, that is, use them with different versions of edm, with this change, this became difficult. I vote for changing this name back to what it was.
Right now it looks like I may have to maintain two versions of edm files to accommodate that change, unless there is an easier way to deal with this, which I have not thought of.
Zen
> -----Original Message-----
> From: John William Sinclair [mailto:[email protected]]
> Sent: Monday, January 30, 2012 9:18 AM
> To: Szalata, Zenon M.
> Subject: Re: edm1-12-69
> Zen,
> Thanks for the info. I also changed the funtion return type to int. This
> code has been modified by a couple of individuals
> and I never noticed the return type before but it was me that added the
> (unsigned int) cast. I made the change and posted
> a new version.
> The huge number of warnings is related to the X11/Motif library usage
> and seems to be the case with the default EPICS makefile
> options. I know of no way to eliminate them.
> No clue as to what the runtime X KEYSYM messages mean.
> Best,
> John Sinclair
> Szalata, Zenon M. wrote:
> > EDM R1-12-69 fails to build on RHEL6 64bit OS. The problem is in
> > calc_pv_factory.cc file in function equals. I have commented the
> > offending lines and added lines with my fix. Here it is:
> > bool equals(const HashedCalcPvList *lhs, const HashedCalcPvList *rhs)
> > // if ( (unsigned int ) lhs->pv < (unsigned int ) rhs->pv ) {
> > if ( (unsigned long ) lhs->pv < (unsigned long ) rhs->pv ) {
> > return 1;
> > // else if ( (unsigned int ) lhs->pv > (unsigned int ) rhs->pv ) {
> > else if ( (unsigned long ) lhs->pv > (unsigned long ) rhs->pv ) {
> > return -1;
> > return 0;
> > I also get an enormous number of warnings.
> > Which version of edm is known to work with RHEL6 64bit Linux?
> > When I run the edm (1-12-69) binary I get the following warnings:
> > zms@ilc-esb09 $ Warning:
> > Class: XmCascadeButton
> > Illegal mnemonic character; Could not convert X KEYSYM to a keycode
> > Warning:
> > Warning:
> > Warning:
> > Warning:
> > Warning:
> > Warning:
> > Warning:
> > Do these indicate that I may be missing something in the motif
> > installation?
> > Thanks for any help,
> > Zen
- edm1-12-69 Szalata, Zenon M.
Re: Cryocool LHe support? Matthias Clausen
std_R3_1 Szalata, Zenon M.
<2012>
2025
2026
EDM dosn't handle file system links Fabian S.
<2012>
2025
2026
