1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM dosn't handle file system links
To: EPICS tech-talk <[email protected]>
Date: Mon, 30 Jan 2012 15:25:12 +0100
Hello TechTalk,
can someone verify that EDM dosn't work very well with hard or
symbolic-links  under linux?
What I did:
created a file and reused it in different projects via link. One day I
edited not the source file rather the link and saved it with "save",
thus breaking the link.
original state:
~/file_lnk.edl ---> /lib/file.edl
1st save:
~/file_link.edl
~/file_lnk.edl~ ---> /lib/file.edl
2nd save:
~/file_link.edl
~/file_lnk.edl~
it seems to happen with softlinks as well as with symlinks. With
symlinks it's easier to investigate. Using hardlinks it helps using
"stat /lib/file.edl" to see if the file has links and "find / -samefile
/lib/file.edl" to see where are these pointing to.
thanks in advance
Fabian
PS works as well "find / -inum ?????"
Re: EDM dosn't handle file system links Andrew Johnson
Prev: edm1-12-69 Szalata, Zenon M.
Next: Re: EDM dosn't handle file system links Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: edm1-12-69 Szalata, Zenon M.
