1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DRVL, DRVH, HOPR, LOPR
To: [email protected]
Cc: [email protected]
Date: Wed, 01 Feb 2012 15:25:00 +0100
> Questions:
> 1. how does one (especially the client) know that the limits are really set? And not default values.
> 2. if it performs a check that HOPR!=LOPR then what if one defines an upper limit (but does not need a low one) and vice-versa.
to 1.)
As pointed out previously: The client does not know it.
Of course DRVH/L are already handled by the record: if DRVH=DRVL=0 then only a "0" can be written to the hardware
But HOPR and LOPR are not used by all clients.
If you want to use them in any client, take care that they are set for ALL records that are meant to be used by any client.
to 2.)
The only way to allow HOPR and LOPR to be set individually would be to change the default: HOPR=+Inf and LOPR=-Inf.
But this is not really useful: e.g. if you want to present a control slider you need two limits to just show it.
And if just one client has a problem with one unset limit, then you'll need to set all limits.
Just drop the idea of not setting HOPR or LOPR for any relevant PV.
Every PV has to have a valid range.
Andreas
Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
[email protected], http://people.web.psi.ch/luedeke
RE: DRVL, DRVH, HOPR, LOPR Abadie Lana
Re: DRVL, DRVH, HOPR, LOPR Dirk Zimoch
Prev: RE: DRVL, DRVH, HOPR, LOPR Dalesio, Leo
Next: RE: DRVL, DRVH, HOPR, LOPR Abadie Lana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mvme6100 HW issues? chris.colborne
