1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DRVL, DRVH, HOPR, LOPR
To: Luedeke Andreas <[email protected]>
Cc: [email protected]
Date: Mon, 13 Feb 2012 09:21:10 +0100
Luedeke Andreas wrote:
Questions: 1. how does one (especially the client) know that the limits are really set? And not default values.
2. if it performs a check that HOPR!=LOPR then what if one defines an upper limit (but does not need a low one) and vice-versa.
to 1.) As pointed out previously: The client does not know it. Of course DRVH/L are already handled by the record: if DRVH=DRVL=0 then only a "0" can be written to the hardware
This is wrong. DRVH and DRVL are only used if DRVH > DRVL.
That means of course in particular if DRVH=DRVL=0 then ANY value can be written.
Thus a client can check for DRVH > DRVL or DRVH!=0 and DRVL!=0.
Dirk
But HOPR and LOPR are not used by all clients. If you want to use them in any client, take care that they are set for ALL records that are meant to be used by any client.
to 2.)
The only way to allow HOPR and LOPR to be set individually would be to change the default: HOPR=+Inf and LOPR=-Inf.
But this is not really useful: e.g. if you want to present a control slider you need two limits to just show it.
And if just one client has a problem with one unset limit, then you'll need to set all limits.
Just drop the idea of not setting HOPR or LOPR for any relevant PV.
Every PV has to have a valid range.
Andreas
Re: DRVL, DRVH, HOPR, LOPR Luedeke Andreas
Prev: cothread time stamp problem Shen, Guobao
Next: Cothread releases 2.4 and 2.5 withdrawn michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: DRVL, DRVH, HOPR, LOPR Gary Croke
Next: asyn reading to waveform records Rod Nussbaumer
