1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cothread problem on Mac osx
To: [email protected]
Cc: [email protected]
Date: Thu, 09 Feb 2012 08:34:42 -0500
The error is as below:
>>> import cothread
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/cothread-2.3-py2.7-macosx-10.6-x86_64.egg/cothread/__init__.py", line 41, in <module>
    from cothread import *
  File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/cothread-2.3-py2.7-macosx-10.6-x86_64.egg/cothread/cothread.py", line 82, in <module>
    import coselect
  File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/cothread-2.3-py2.7-macosx-10.6-x86_64.egg/cothread/coselect.py", line 60, in <module>
    _select_poll = _select.poll
AttributeError: 'module' object has no attribute 'poll'
which is caused by the line 60 in coselect.py.
( _select_poll = _select.poll )
The platform is not tested here, which caused the import error.
Guobao
On 2/9/12 8:10 AM, [email protected] wrote:
I am using exact the version 2.3 which is from that link.
Did not try your git repo version yet.
Ah.
I *thought* that cothread was working properly under OSX, it was the last time I tried ... which may have been too long ago.
That's a shame, I've just made a 2.4 release, which won't address your problem.
Can you take a closer look and tell me what's happening?  I'm puzzled that you're reporting that cothread is using poll(), because I have the following lines in coselect.py:
import platform as _platform
if hasattr(_select, 'poll'):
     if _platform.system() == 'Darwin':
         # Unfortunately it would appear that Apple's implementation of the
         # poll() system call is incomplete: it returns POLLNVAL for devices!
         # Apparently kqueue and poll fail on anything in /dev (I suppose they
         # work on ordinary files and sockets?)
         #   So if this is your platform, sorry, we have to use select.
         poll_block = poll_block_select
     else:
         # This is the preferred case.
         poll_block = poll_block_poll
The poll_block_select() function does its best to emulate poll() using select(), and it worked last time I looked, at least I thought so.  Can you check that, for example, that this code is actually working (maybe _platform.system() has changed, for example?)
Guobao Shen
Bldg. 902-B, 17 Cornell Avenue
National Synchrotron Light Source II
Brookhaven National Laboratory
Upton, New York 11973
Tel.	: +1 (631) 344 7540
Fax.	: +1 (631) 344 8085
http://www.bnl.gov/nsls2
RE: cothread problem on Mac osx michael.abbott
cothread problem on Mac osx Shen, Guobao
RE: cothread problem on Mac osx Shen, Guobao
Prev: Re: VME SCALER, I2C bus Tim Mooney
Next: RE: VME SCALER, I2C bus Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: cothread problem on Mac osx michael.abbott
Next: RE: cothread problem on Mac osx michael.abbott
