1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform record missing fields
To: [email protected]
Date: Fri, 10 Feb 2012 14:27:17 -0500
Hi Mark,
http://bazaar.launchpad.net/~epics-core/epics-base/3.14/changes?filter_file_id=waveformrecord.dbd-19960624131907-wwx9ykn4t0kkjfg8-41
The short answer is that these fields haven't ever existed in waveformRecord.dbd.
Michael
On 2/10/2012 1:49 PM, Mark Rivers wrote:
Folks,
All versions of the EPICS Record Reference Manual from 3.13 to 3.14.12.2 document the following 2 fields in the waveform record:
RATE Sampling Rate       Some device support modules may find this useful.
PTSS Pre-trigger Samples Some device support modules may find this useful.
I really need to use these 2 fields in some new asyn device support I am writing.  (This device support will allow me to remove the dependence of areaDetector on mca).
But these fields do not actually exist in the waveform record, at least for any version of base from 3.14.8.2 to 3.14.12.2!
I cannot find anything in the 3.13 or 3.14 release notes that mentions removing these fields.
Questions:
- Did these fields ever exist?
- Should they be added?
- If so, then while we are adding these fields are there others we should also add that would not break backward compatibility?
Here are is one that I can think of:
NUSE: The number of elements in the waveform to actually use.  Must be<=NELM.
Also, the record does not post monitors on the BUSY or NORD fields.  Should this be the responsibility of device support, or does that code belong in the record?
Waveform record missing fields Mark Rivers
Prev: Waveform record missing fields Mark Rivers
Next: RE: Waveform record missing fields Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
