Hi Mark,
> NUSE: The number of elements in the waveform to actually use. Must be <=NELM.
I think you intend this record to be something you can caput? If yes, maybe better to call it something other than NUSE since NUSE for a compressRecord is not modifiable (NUSE for a compress is the same concept as NORD for a waveform). Maybe "NINP" instead.
> Also, the record does not post monitors on the BUSY or NORD fields. Should this be the
> responsibility of device support, or does that code belong in the record?
I think the code belongs in the record. It would be very nice to have monitors on NORD!
Thank you!
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Mark Rivers
> Sent: Friday, February 10, 2012 10:50 AM
> To: [email protected]
> Subject: Waveform record missing fields
> Folks,
> All versions of the EPICS Record Reference Manual from 3.13 to 3.14.12.2 document the
> following 2 fields in the waveform record:
> RATE Sampling Rate Some device support modules may find this useful.
> PTSS Pre-trigger Samples Some device support modules may find this useful.
> I really need to use these 2 fields in some new asyn device support I am writing. (This
> device support will allow me to remove the dependence of areaDetector on mca).
> But these fields do not actually exist in the waveform record, at least for any version of base
> from 3.14.8.2 to 3.14.12.2!
> I cannot find anything in the 3.13 or 3.14 release notes that mentions removing these fields.
> Questions:
> - Did these fields ever exist?
> - Should they be added?
> - If so, then while we are adding these fields are there others we should also add that would
> not break backward compatibility?
> Here are is one that I can think of:
> Thanks,
> Mark
- Waveform record missing fields Mark Rivers
Re: Waveform record missing fields Michael Davidsaver
Re: Waveform record missing fields Andrew Johnson
<2012>
2025
2026
<2012>
2025
2026
