1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform record missing fields
To: [email protected], Mark Rivers <[email protected]>
Date: Fri, 10 Feb 2012 15:24:52 -0600
Hi Mark,
On 2012-02-10 Mark Rivers wrote:
> Questions:
> - Did these fields ever exist?
Probably at one time, but as Michael has shown there is no record of them in
the revision control history so they were removed before we started using CVS
in about 1994.
> - Should they be added?
> - If so, then while we are adding these fields are there others we should
>  also add that would not break backward compatibility?
How about adding some generic parameter fields instead: A double field for the
parameter value and an associated string field that the device support can set
it its init_record() routine to describe it.  I wonder if they couldn't just
be separate records though, how about using ao, bo, longout, mbbo and
stringout records to set parameters for the waveform acquisition?
> Here are is one that I can think of:
> NUSE: The number of elements in the waveform to actually use.  Must be
>  <=NELM.
Is this meant to tell input device support how many elements to try and read?
> Also, the record does not post monitors on the BUSY or NORD fields.  Should
> this be the responsibility of device support, or does that code belong in
> the record?
Both those fields are currently documented as Rec Proc Monitor = NO, but that
doesn't mean we can't change them.  The record code only looks at BUSY in one
place and never sets it itself; I think if device support sets it and wants
the world to know about changes it should post its own monitors on BUSY.
There are a couple of places where the record code sets NORD: after an array
put, and in simulation mode.  I could accept that the record support should
post monitors when it sets NORD, but it should be the device support's
responsibility when it does so.  This would be a 3.15 change.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
RE: Waveform record missing fields Mark Rivers
Prev: RE: Waveform record missing fields Allison, Stephanie
Next: RE: Waveform record missing fields Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
